The expansiveness of this 37.5-inch curved screen paired with virtually borderless InfinityEdge creates a near-complete field view which provides an almost uniform visual focus that reduces eye movement across the screen. You'll work more comfortably with fewer distractions and more productivity.
Gorgeous visuals are only the beginning
You'll be oblivious to distractions. Your 37.5-inch, ultra wide curved monitor has a 21:9 aspect ratio and delivers approximately 25 percent more screen content than a 34-inch. Plus a gorgeous, expansive display with InfinityEdge offers virtually borderless screen. -
All-encompassing experience
The curved screen delivers a panoramic viewing experience while integrated 9W speakers bring the quality sound - a one-two punch that makes this monitor the ideal canvas for video editing projects. -
More show than tell
You can expect outstanding detail and consistent color across a wide viewing angle - WQHD+ 3840 x 1600 screen featuring In-Plane Switching technology. -
Accurate color, right out of the box
Your monitor comes with 99% sRGB factory calibration for impressively precise color at Delta-E less than 2. -
Easy on the eyes
This monitor has a flicker-free screen with ComfortView, a feature that filters harmful blue light emissions to optimize eye comfort. -
Get it done
With features like Dell Easy Arrange, you can arrange your projects to best suit your screen space, while Picture-in-Picture and Picture-by-picture (PbP) allow you to display content from two PC sources simultaneously. -
Masterful manageability
You can display and edit content from two different PCs with a single KVM feature (keyboard, video and mouse). -
Convenient connectivity
A single cable solution with a USB Type-C connectivity transmits power, audio and video signals between a laptop and monitor. Connect and charge from a single source while reducing cable clutter.
- Dell UltraSharp U3818DW - LED monitor - curved - 38"
- LED-backlit LCD monitor - 38"
- Energy Class
- Class A
- Energy Consumption per Year
- 69 kWh
- Power Consumption (On mode)
- 47 W
- Curved Screen
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- WQHD+ 3840 x 1600 (DisplayPort: 60 Hz, HDMI: 60 Hz)
- Pixel Pitch
- 0.229 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (normal); 5 ms (fast)
- Colour Support
- 1.07 billion colours
- Input Connectors
- 2xHDMI, DisplayPort
- Height, swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Black
- 89.4 cm x 22.64 cm x 43.2 cm
- 12.1 kg
- Plug and Play, TUV, RoHS, WEEE, E-Standby, ERP, CEL, EuP, BFR, China Energy Label
- Bundled Services
- 3 years Advanced Exchange Service
- Designed For
- XPS 13 9380, 15 9570, 15 9575 2-in-1
- Display Type
- Energy Class
- Class A
- 69 kWh
- Diagonal Size
- 38"
- Viewable Size
- 37.5"
- Curved Screen
- Yes (2300R)
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Pixel Pitch
- 0.229 mm
- Pixel Per Inch
- 111
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture in picture, picture by picture, 99% sRGB colour gamut, Flicker Free technology, Wide Viewing Angle, 99% Rec 709 colour gamut, Ultra Slim Design Bezel, 78.1% DCI-P3
- Black
- 89.4 cm x 22.64 cm x 43.2 cm - with stand
- 12.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 9 Watt
- 2 x HDMI , DisplayPort , 2 x USB 3.0 upstream , 4 x USB 3.0 downstream , USB-C , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, PVC free, anti-theft stand lock slot
- Cables Included
- 1 x DisplayPort cable , 1 x SuperSpeed USB cable , USB-C cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 100/240 V (50/60 Hz)
- 47 W
- 56 Watt
- Power Consumption (Typical)
- 56 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 89.4 cm - depth: 22.64 cm - height: 43.2 cm - weight: 12.1 kg , Without stand - width: 89.4 cm - depth: 5.55 cm - height: 39.68 cm - weight: 9.1 kg
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell XPS 13 9380, 15 9570, 15 9575 2-in-1
