Dell UltraSharp 34" 3440x1440 8ms HDMI DP USB 4K Curved Monitor
Quicklinx: B15ZWS00 Mfr#: 210-ADYO
Diagonal Size: 34.08in
Max Resolution: 3440 x 1440
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
More than 50 in stock
£532.08 ex VAT
£638.49 inc VAT
Discover one of the world’s first 34 inch 21:9 curved monitors with a panoramic view, cinematic WQHD resolution and superb sound. The Dell UltraSharp 34 inch Curved Monitor engages you in a wrap-around viewing experience with a 21:9 ultra-wide curved screen that offers more display area and enhanced viewing comfort. Navigate across multiple applications and video inputs with Picture by Picture and Picture in Picture features.
  • Transport yourself to another world
    Enter a new dimension of multitasking with a curved monitor that delivers an immersive, panoramic screen that surrounds your senses with amazingly detailed edge-to-edge WQHD (3440x1440) imagery and crystal-clear sound. With a field of view that enlists both your primary and peripheral fields of vision, the 34-inch 21:9 curved screen provides an amazing, in-the-action experience. Rich and engaging sound from dual 9 watt (18W total) integrated speakers transports you further into your digital world. Increase viewing comfort with a more uniform focal distance. This means that with a curved screen, you won’t move your eyes as much as with a flat-screen monitor.
  • Productive across all screens
    Easily display content from two different PCs at the same time with the Picture-by-picture or Picture-in-picture features, via the USB 3.0 upstream ports. Plus enjoy the convenience of using just one keyboard and mouse to navigate content from both PCs. Maximize your multitasking by connecting multiple monitors and peripherals for massive screen real estate. View seamlessly across multiple monitors by placing the thinnest edges side-by-side for an enhanced viewing experience. Connect your smartphone or tablet to your monitor using Mini DisplayPort, or use HDMI 2.0 to get the best of the Internet and your favorite apps by displaying in full 21:9 aspect ratio. Stay organized between applications, emails and Windows on one screen using Dell Easy Arrange. Customize your viewing experience with adjustable height, tilt and swivel options.
  • Environmentally-conscious design
    Made with eco-friendly materials, the U3415W is BFR/PVC-free and has an arsenic-free glass and mercury-free LED panel. Enhanced power management with PowerNap dims the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell UltraSharp U3415W - LED monitor - curved - 34.08"
LED-backlit LCD monitor - 34.08"
Energy Class
Class B
Energy Consumption per Year
70 kWh
Power Consumption (On mode)
48 W
Curved Screen
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
2xHDMI, DisplayPort, Mini DisplayPort, MHL
Speakers
Integrated
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
82.47 cm x 21.6 cm x 40.87 cm
10.8 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Plug and Play, DDC/CI, NFPA 99
Display Type
Energy Class
Class B
70 kWh
48 W
Diagonal Size
34.08"
Viewable Size
34.08"
Curved Screen
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
48 - 85 Hz
Horizontal Refresh Rate
30 - 89 kHz
Video Bandwidth
319.8 MHz
Horizontal Viewing Angle
172
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Volume, brightness, contrast, sharpness, saturation, gamma correction, input select, colour temperature, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, PBP, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut, High Bit Rate 2 (HBR2)
82.47 cm x 21.6 cm x 40.87 cm - with stand
10.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
9 Watt
MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 4 x USB 3.0 downstream , 2 x USB 3.0 upstream , Audio line-out , DisplayPort , HDMI
Mechanical
Tilt Angle
-5/+21
Swivel Angle
60
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable , 1 x HDMI cable
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
130 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Microsoft Windows 7 / 8 / 8.1
Dimensions & Weight Details
With stand - width: 82.47 cm - depth: 21.6 cm - height: 40.87 cm - weight: 10.8 kg , Without stand - width: 82.47 cm - depth: 7.33 cm - height: 37.2 cm - weight: 8.44 kg
10 - 80% (non-condensing)
Dell UltraSharp 34 Bundle deal on Dell UltraSharp 34" 3440x1440 8ms HDMI DP USB 4K Curved Monitor
£631.25
B15Z C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
B15Z C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.31
B15Z C2G 5m Select High Speed HDMI with Ethernet In Stock £21.06
B15Z C2G 15m Select High Speed HDMI with Ethernet In Stock £54.75
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 500 - 750
