Color-critical performance. 30" monitor with PremierColor that delivers every creative professional their ideal color space. You'll have precise, professional color right out of the box with flexibility to adjust it to your preferences with PremierColor. View and manage applications between two PCs simultaneously with KVM, PBP and PIP features. Or extend to a secondary monitor with a daisy chain for maximum multitasking.
Precise color, out of the box
With a factory calibration report and a Delta-E > 2, you can be confident that your colors will be impressively accurate right from the start. -
Wide color coverage
Major industry standards such as AdobeRGB, sRGB, REC709 and DCI-P3 are 99% covered. -
Exceptional detail
With 1.07 billion colors, you can see more details in higher clarity, even across an ultra-wide viewing angle. -
Expanded canvas
Advanced connectivity (DP-out) allows for simple daisy chain extension into a second screen. -
View tailored to you
Easily display content from two PC sources with picture-by-picture and picture-in-picture features. Plus the KVM feature enables you to manage content with a single keyboard and mouse. -
Stay connected
A wide range of connectivity ports ensure that you can connect your secondary devices without extra hardware. -
Work comfortably
With height-adjustable, tilt, swivel and pivot features, you can collaborate and work with ease.
- Dell UltraSharp UP3017 - LED monitor - 30"
- LED-backlit LCD monitor - 30"
- Energy Class
- Class B
- Energy Consumption per Year
- 73 kWh
- Power Consumption (On mode)
- 54 W
- Daisy Chaining
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 2560 x 1600 at 60 Hz
- Pixel Pitch
- 0.251 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey), 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% Adobe RGB, 99% sRGB
- Input Connectors
- 2xHDMI, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- 68.69 cm x 21.7 cm x 48.23 cm
- 9.59 kg
- Plug and Play, RoHS, BFR
- Bundled Services
- 3 years Advanced Exchange Service
- Display Type
- Energy Class
- Class B
- 73 kWh
- Diagonal Size
- 30"
- Daisy Chaining
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.251 mm
- Pixel Per Inch
- 101
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Picture by picture, HDCP, PremierColor technology, Flicker Free technology, Energy Gauge, Premium Panel Guarantee, Mercury free, Colour Calibration, arsenic-free glass, Dell ComfortView, Picture-in-Picture, 99% sRGB colour gamut
- 68.69 cm x 21.7 cm x 48.23 cm - with stand
- 9.59 kg
- DisplayPort (HDCP) , Mini DisplayPort (HDCP) , 2 x HDMI (HDCP) , DisplayPort output (MST) , 2 x USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 downstream with Battery Charging 1.2 , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, anti-theft protection, Dell Soundbar mounting slots
- Cables Included
- 1 x SuperSpeed USB cable , 1 x Mini DisplayPort-DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 54 W
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 68.69 cm - depth: 21.7 cm - height: 48.23 cm - weight: 9.59 kg , Without stand - width: 68.69 cm - depth: 5.8 cm - height: 44.71 cm - weight: 6.49 kg
- Bundled Services
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 20cm Mini DisplayPort Male to HDMI Female Adapter Black | In Stock | £16.42 |
C2G 20cm Mini DisplayPort Male to VGA Female Adapter Black | In Stock | £17.40 |
