Dell UltraSharp 27" UP2715K 3840x2160 8ms DP USB LED 5K Monitor
Quicklinx: B162WS00 Mfr#: 210-ADSG
Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K monitor - UP2715K features an astoundingly vivid Ultra HD resolution. That's a dramatic increase in screen clarity, with more pixels - or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies.
  • The most detail you've ever seen on a monitor screen
  • Design and edit to perfection
    If you're a graphics or design professional in the entertainment, film, photography or engineering field, you'll immediately recognize the benefits of a 5K monitor with Dell PremierColor. Details this incredible allow you to view your work with a whole new level of insight.
  • Clear views and crystal-clear sound
    Incredible clarity of an edge-to-edge display combines with high-power, high-end stereo speakers for an immersive audio and video experience.
  • Superb usability
    Take in the fine, almost infinite, detail provided by the Dell UltraSharp 27 Ultra HD 5K Monitor - UP2715K in total comfort, thanks to its wide-ranging adjustability.
Dell UltraSharp UP2715K - LED monitor - 27"
LED-backlit LCD monitor - 27"
Card reader, USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
Pixel Pitch
0.116 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
100% sRGB, 99% Adobe RGB
Input Connectors
2xDisplayPort, Mini DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-reflective, anti-smudge coating
Voltage
63.73 cm x 20.45 cm x 42.76 cm
9.38 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, VESA EDID, DDC/CI, RoHS, NFPA 99
Display Type
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.116 mm
Pixel Per Inch
218
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
30 - 60 Hz
Horizontal Refresh Rate
31 - 180 kHz
Video Bandwidth
483.3 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Volume, brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control, colour space, gain, offset
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
PremierColor technology, LED edgelight system, stand lock, Dell Custom Color, BFR/PVC-free, Energy Gauge, Mercury free, Factory Calibration, 6-axis colour adjustment, High Bit Rate 2 (HBR2)
63.73 cm x 20.45 cm x 42.76 cm - with stand
9.38 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
16 Watt
2 x DisplayPort , Mini DisplayPort , USB 3.0 upstream , 5 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Harman Kardon speakers
Stand, cleaning cloth, cable management cover
2 x DisplayPort cable - 1.8 m , 2 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
170 Watt
Power Consumption Stand by
1.2 Watt
Power Consumption Sleep
1.2 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 63.73 cm - depth: 20.45 cm - height: 42.76 cm - weight: 9.38 kg , Without stand - width: 63.73 cm - depth: 4.79 cm - height: 38.46 cm - weight: 7.14 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
B162 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
