Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K monitor - UP2715K features an astoundingly vivid Ultra HD resolution. That's a dramatic increase in screen clarity, with more pixels - or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies.
The most detail you've ever seen on a monitor screen
Welcome to the amazing sharpness and clarity of a 5K monitor. The Dell UltraSharp 27 Ultra HD 5K monitor - UP2715K features an astoundingly vivid Ultra HD resolution. That's a dramatic increase in screen clarity, with more pixels - or four times the content of QHD resolution, seven times the content of Full HD displays and almost double the number of pixels in an Ultra HD 4K monitor. The result is a breakthrough visual experience that brings outstanding realism, depth and crispness to pictures and movies. -
Design and edit to perfection
If you're a graphics or design professional in the entertainment, film, photography or engineering field, you'll immediately recognize the benefits of a 5K monitor with Dell PremierColor. Details this incredible allow you to view your work with a whole new level of insight. -
Clear views and crystal-clear sound
Incredible clarity of an edge-to-edge display combines with high-power, high-end stereo speakers for an immersive audio and video experience. -
Superb usability
Take in the fine, almost infinite, detail provided by the Dell UltraSharp 27 Ultra HD 5K Monitor - UP2715K in total comfort, thanks to its wide-ranging adjustability.
- Dell UltraSharp UP2715K - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Card reader, USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 5K Ultra HD (2880p) 5120 x 2880 at 60 Hz
- Pixel Pitch
- 0.116 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 100% sRGB, 99% Adobe RGB
- Input Connectors
- 2xDisplayPort, Mini DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-reflective, anti-smudge coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 63.73 cm x 20.45 cm x 42.76 cm
- 9.38 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, VESA EDID, DDC/CI, RoHS, NFPA 99
- Display Type
- Diagonal Size
- 27"
- Built-in Devices
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.116 mm
- Pixel Per Inch
- 218
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 30 - 60 Hz
- Horizontal Refresh Rate
- 31 - 180 kHz
- Video Bandwidth
- 483.3 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 10000K
- Controls & Adjustments
- Volume, brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control, colour space, gain, offset
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- PremierColor technology, LED edgelight system, stand lock, Dell Custom Color, BFR/PVC-free, Energy Gauge, Mercury free, Factory Calibration, 6-axis colour adjustment, High Bit Rate 2 (HBR2)
- Black
- 63.73 cm x 20.45 cm x 42.76 cm - with stand
- 9.38 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 16 Watt
- 2 x DisplayPort , Mini DisplayPort , USB 3.0 upstream , 5 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Harman Kardon speakers
- Included Accessories
- Stand, cleaning cloth, cable management cover
- Cables Included
- 2 x DisplayPort cable - 1.8 m , 2 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x Mini DisplayPort cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 170 Watt
- Power Consumption Stand by
- 1.2 Watt
- Power Consumption Sleep
- 1.2 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 63.73 cm - depth: 20.45 cm - height: 42.76 cm - weight: 9.38 kg , Without stand - width: 63.73 cm - depth: 4.79 cm - height: 38.46 cm - weight: 7.14 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable | In Stock | £32.58 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.82 |
