Dell U2913WM 29" 2560x1080 VGA DVI DP HDMI USB LED Monitor
Quicklinx: 9057WS00 Mfr#: 210-41199
Experience the panoramic 29" Dell UltraSharp U2913WM, featuring 2560 x 1080 Full HD, versatile connectivity and innovative productivity features. Navigate multiple applications at once and multitask like never before. A vast, 29" panoramic display with 21:9 aspect ratio and 2560 x 1080 Full HD offers the screen space of side-by-side monitors without a distracting bezel in between. Plus, with a 178-degree/178-degree ultra-wide viewing angle, you can enjoy an excellent view from almost any position.
  • Surround yourself with panoramic widescreen
  • Immerse yourself in vivid color
    Experience remarkably precise and accurate color made possible by over 99 percent sRGB at a delta-E of less than 5, offering broad color variation. Plus, the U2913WM come factory color-calibrated, so you can enjoy outstanding color accuracy right out of the box.
  • Connect peripherals and make yourself comfortable
    Make it work for you, with extensive connectivity such as DisplayPort, USB 3.0, mini DisplayPort, DVI and HDMI, plus highly adjustable tilt and swivel positioning, a 130 mm height adjustability range and a VESA-compatible wall mounting option.
  • Work smart with Dell display manager
    Synchronize your applications and improve your visual experience. Dell display manager offers a variety of features that can optimize your media presentation and maximize your monitor's real estate, such as easy arrange and auto mode.
  • Your videos never looked so good
    Automatically optimize your video settings with the smart video enhance feature, optimizing colors and sharpness for the best possible presentation.
  • Contain costs and stay conscious of the environment
    Stay energy-efficient with PowerNap and dynamic dimming features that automatically help regulate power usage. Plus, the U2913WM features an eco-conscious design with arsenic-free glass, mercury-free LED and BFR/PVC-free laminates in the chassis. The U2913WM is EPEAT Gold and ENERGY STAR qualified and comes packed in eco-conscious recyclable packaging.
Dell UltraSharp U2913WM - LED monitor - 29"
LED-backlit LCD monitor - 29"
Energy Class
Class B
Energy Consumption per Year
47 kWh
Power Consumption (On mode)
32 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
2560 x 1080 at 60 Hz
Pixel Pitch
0.09 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
82% (CIE 1976), 99% sRGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
69.98 cm x 19.42 cm x 35.87 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
3-year warranty
Display Type
Energy Class
Class B
47 kWh
Diagonal Size
29"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.09 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
8 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
HDCP, integrated cable management, 99% sRGB colour gamut
69.98 cm x 19.42 cm x 35.87 cm - with stand
DVI-D (dual link) (HDCP) , DisplayPort , Mini DisplayPort , HDMI , VGA , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out , DisplayPort output
Mechanical
Height Adjustment
130 mm
VESA Mounting Interface
Security lock slot (cable lock sold separately), anti-theft ring, integrated cable management
Cable tie
1 x DVI cable , 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
32 W
Power Consumption (Typical)
32 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Driver
Dimensions & Weight Details
With stand - width: 69.98 cm - depth: 19.42 cm - height: 35.87 cm , Without stand - width: 69.98 cm - depth: 6.12 cm - height: 31.7 cm - weight: 5.76 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
9057 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
