Dell U2718Q UltraSharp 27" 3840x2160 8ms HDMI LED LCD Monitor
Quicklinx: DVX8WS00 Mfr#: DELL-U2718Q
Diagonal Size: 27in
Max Resolution: 3840 x 2160
Response Time: 5ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort
Stock Status: In Stock, Used Stock
More than 50 in stock
£497.41 ex VAT
£596.89 inc VAT
Standard delivery Delivered within 3-5 working days
With your UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking. Featuring a striking color depth of 1.07 billion colors, your work is presented in outstanding detail, even in dark or brightly lit areas.
Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images.
Your UltraSharp monitor is factory calibrated at 99.9% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Each monitor features a factory calibration report that guarantees color correctness, so you can trust your projects reflect true color intensity.
  • See the whole picture
  • A captivating view
  • Color consistency comes standard
  • Uncompromised images
    View your HDR10 content like it was meant to be seen. Even your HDR photos will boast a lifelike experience.
  • Get it all done
    Staying on task doesn't mean sacrificing comfort. Discover the best of both worlds with this TUV-Certified monitor that's as efficient as it is effortless to use.
Dell UltraSharp U2718Q - LED monitor - 4K - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
44 kWh
Power Consumption (On mode)
30 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1554 mm
Brightness
350 cd/m²
Contrast Ratio
1300:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
61.13 cm x 20.03 cm x 41.02 cm
6.23 kg
Environmental Standards
TCO Certified Displays 8
Plug and Play, DDC/CI, RoHS, NFPA 99, halogen-free, EDID compatible, BFR-free, HDCP 2.2
Latitude 7400 2-in-1; XPS 13 9380, 15 9570, 15 9575 2-in-1
Display Type
Energy Class
Class A
44 kWh
30 W
Diagonal Size
27"
Viewable Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1554 mm
Pixel Per Inch
163
Brightness
350 cd/m²
Contrast Ratio
1300:1
Colour Support
Response Time
Vertical Refresh Rate
49 - 86 Hz
Horizontal Refresh Rate
10 - 137 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 6500K, 7500K, 10000K, 5700K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
HDCP, game mode, LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, 99.9% sRGB colour gamut, arsenic-free glass, Factory Calibration Report, Infinity Edge display, Dell Easy Arrange, Eye comfort mode, Dell ComfortView, Wide Viewing Angle, Colour Temperature Selection, Movie Mode, borderless, HDR (high dynamic range), 99.98% Rec 709 colour gamut, 80.7% DCI-P3, ultra-thin frame bezel
61.13 cm x 20.03 cm x 41.02 cm - with stand
6.23 kg
HDMI (HDCP) , DisplayPort (DisplayPort 1.2 mode) , Mini DisplayPort (HDCP) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream with Battery Charging 1.2 (Type A) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, anti-theft protection, PVC free, arsenic free
1 x SuperSpeed USB cable , 1 x Mini DisplayPort-DisplayPort cable
Security Slot Type
Kensington security slot
30 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, Dell Display Manager
Microsoft Windows 7, Windows 8 / 8.1 / 10
Dimensions & Weight Details
With stand - width: 61.13 cm - depth: 20.03 cm - height: 41.02 cm - weight: 6.23 kg , Without stand - width: 61.13 cm - depth: 4.91 cm - height: 35.62 cm - weight: 3.7 kg
Shipping Weight
9.4 kg
TCO Certified
10 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570, 15 9575 2-in-1
Dell U2718Q UltraSharp 27 Bundle deal on Dell U2718Q UltraSharp 27" 3840x2160 8ms HDMI LED LCD Monitor
£596.58
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DVX8 042080
Condition: Customer return - item has been replaced under warranty by the manufacturer. Please note. Model U2720Q will be received.
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £443.19
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 27in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: Dell
Stock Status: Used Stock
Price Range Ex VAT: 300 - 500
