With your UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking. Featuring a striking color depth of 1.07 billion colors, your work is presented in outstanding detail, even in dark or brightly lit areas.
Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images.
Your UltraSharp monitor is factory calibrated at 99.9% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Each monitor features a factory calibration report that guarantees color correctness, so you can trust your projects reflect true color intensity.
See the whole picture
With your UltraSharp monitor you get more than a pretty picture - it's a gorgeous screen made for multitasking. Featuring a striking color depth of 1.07 billion colors, your work is presented in outstanding detail, even in dark or brightly lit areas. -
A captivating view
Dell HDR combines greater depth of colors, remarkable clarity and a high contrast range of shades to create strikingly realistic images. -
Color consistency comes standard
Your UltraSharp monitor is factory calibrated at 99.9% sRGB coverage to an accuracy of Delta-E less than 2, for precise hues right out of the box. Each monitor features a factory calibration report that guarantees color correctness, so you can trust your projects reflect true color intensity. -
Uncompromised images
View your HDR10 content like it was meant to be seen. Even your HDR photos will boast a lifelike experience. -
Get it all done
Staying on task doesn't mean sacrificing comfort. Discover the best of both worlds with this TUV-Certified monitor that's as efficient as it is effortless to use.
- Dell UltraSharp U2718Q - LED monitor - 4K - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 44 kWh
- Power Consumption (On mode)
- 30 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1300:1
- Response Time
- 5 ms (fast), 8 ms (normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 80.7% DCI-P3, 99.9% sRGB, 99.98% Rec 709
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.13 cm x 20.03 cm x 41.02 cm
- 6.23 kg
- Plug and Play, DDC/CI, RoHS, NFPA 99, halogen-free, EDID compatible, BFR-free, HDCP 2.2
- Designed For
- Latitude 7400 2-in-1; XPS 13 9380, 15 9570, 15 9575 2-in-1
- Display Type
- Energy Class
- Class A
- 44 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1300:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 49 - 86 Hz
- Horizontal Refresh Rate
- 10 - 137 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 6500K, 7500K, 10000K, 5700K
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- HDCP, game mode, LED edgelight system, stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, Infinity Edge display, Dell Easy Arrange, Eye comfort mode, Dell ComfortView, Wide Viewing Angle, Colour Temperature Selection, Movie Mode, borderless, ultra-thin frame bezel
- Black
- 61.13 cm x 20.03 cm x 41.02 cm - with stand
- 6.23 kg
- HDMI (HDCP) , DisplayPort 1.2 , Mini DisplayPort (HDCP) , 2 x USB 3.0 downstream (Type A) , 2 x USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream with Battery Charging 1.2 (Type A) , Audio line-out (mini-jack)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support, anti-theft protection, PVC free, arsenic free
- Cables Included
- 1 x SuperSpeed USB cable , 1 x Mini DisplayPort-DisplayPort cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 30 W
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Dell Display Manager
- OS Required
- Microsoft Windows 7, Windows 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand - width: 61.13 cm - depth: 20.03 cm - height: 41.02 cm - weight: 6.23 kg , Without stand - width: 61.13 cm - depth: 4.91 cm - height: 35.62 cm - weight: 3.7 kg
- Shipping Weight
- 9.4 kg
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
- Designed For
- Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570, 15 9575 2-in-1
