Superior screen resolution and real estate for a view you can't wait to get your eyes on. Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals. Your Dell UltraSharp 27 monitor - U2715H is designed to be pixel perfect. Complete your Dell monitor experience. Your Dell UltraSharp 27 monitor - U2715H is just the start. Look for these great accessories when finalizing your purchase.
A performance that deserves applause
Superior screen resolution and real estate for a view you can't wait to get your eyes on. -
Designed for your comfort and convenience
Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals. -
Reliable and eco-efficient
Your Dell UltraSharp 27 monitor - U2715H is designed to be pixel perfect. -
Get the most from your monitor
- Dell UltraSharp U2715H - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 48 kWh
- Power Consumption (On mode)
- 33 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 60 Hz
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 76% (CIE 1931), 91% (CIE 1976), 99% sRGB
- Input Connectors
- 2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.27 cm x 20.5 cm x 40.99 cm
- Localisation
- United Kingdom
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, FCC, DDC/CI, RoHS, NFPA 99
- Display Type
- Energy Class
- Class B
- 48 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 86 Hz
- Horizontal Refresh Rate
- 30 - 113 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 9300K, 5000K, 6500K, 7500K, 10000K, 5700K
- Controls & Adjustments
- Brightness, contrast, sharpness, saturation, input select, colour temperature, hue, aspect control
- LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 99% sRGB colour gamut
- Black
- 61.27 cm x 20.5 cm x 40.99 cm - with stand
- 2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
- Localisation
- United Kingdom
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 33 W
- Power Consumption (Typical)
- 88 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities
- Dimensions & Weight Details
- With stand - width: 61.27 cm - depth: 20.5 cm - height: 40.99 cm , Without stand - width: 61.27 cm - depth: 4.64 cm - height: 36.34 cm - weight: 4.91 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
