Dell U2715H 27" 2560x1440 IPS Monitor
Quicklinx: 9ZV3WS00 Mfr#: 210-ADSN
Superior screen resolution and real estate for a view you can't wait to get your eyes on. Work the way you want. Position your monitor for ultimate comfort with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals. Your Dell UltraSharp 27 monitor - U2715H is designed to be pixel perfect. Complete your Dell monitor experience. Your Dell UltraSharp 27 monitor - U2715H is just the start. Look for these great accessories when finalizing your purchase.
  • A performance that deserves applause
  • Designed for your comfort and convenience
  • Reliable and eco-efficient
  • Get the most from your monitor
Dell UltraSharp U2715H - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
48 kWh
Power Consumption (On mode)
33 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 60 Hz
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Colour Gamut
76% (CIE 1931), 91% (CIE 1976), 99% sRGB
Input Connectors
2xHDMI, 2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
61.27 cm x 20.5 cm x 40.99 cm
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC, DDC/CI, RoHS, NFPA 99
Display Type
Energy Class
Class B
48 kWh
Diagonal Size
27"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 86 Hz
Horizontal Refresh Rate
30 - 113 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
Controls & Adjustments
Brightness, contrast, sharpness, saturation, input select, colour temperature, hue, aspect control
LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 99% sRGB colour gamut
61.27 cm x 20.5 cm x 40.99 cm - with stand
2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
United Kingdom
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
33 W
Power Consumption (Typical)
88 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Included Software
Drivers & Utilities
Dimensions & Weight Details
With stand - width: 61.27 cm - depth: 20.5 cm - height: 40.99 cm , Without stand - width: 61.27 cm - depth: 4.64 cm - height: 36.34 cm - weight: 4.91 kg
Sustainability Information
ENERGY STAR Certified
10 - 80% (non-condensing)
9ZV3 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
