Product
Dell U2417HWi UltraSharp 24" 1920 x 1080 HDMI USB Monitor
Quicklinx: CB58WS00 Mfr#: 210-AIHU
This monitor lets you wirelessly display and edit from two mobile devices on a single monitor screen.
  • Simplified connectivity
    Connect your laptop and smartphone without cables for seamless connectivity.
  • Easy multitasking
    Simultaneously display and edit content from your laptop and smartphone/tablet with a single keyboard and mouse and navigate across both screens with the same mouse.
  • Seamless transition
    Switch smoothly between your smartphone and tablet to your monitor screen and back again.
  • Built for everyday business situations
    Maximize your workday and multitask on the go in multiple ways. Transition between your laptop and smartphone and tablet and edit with a single keyboard and mouse.
  • Superb clarity and color
    A beautiful 23.8-inch Full HD display ensures consistent clarity from any angle.
  • Better view
    Experience an almost borderless view with an ultrathin bezel and an ultra-wide 178°/178° viewing angle.
  • Fully adjustable
    Adjust height, tilt, pivot or swivel for comfortable viewing.
  • Easy connectivity
    HDMI, audio line-out and four USB 3.0 ports make connectivity easy.
Dell UltraSharp U2417HWi - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
18 W
Wi-Fi, USB 3.0 hub, Bluetooth adapter
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
14 ms (grey-to-grey), 8 ms (overdrive)
Colour Support
16.8 million colours
Input Connectors
HDMI, 802.11ac
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
53.91 cm x 18.5 cm x 35.58 cm
5.12 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, NFPA 99, TCO Displays, EDID compatible, IEEE 802.11ac
Display Type
Energy Class
Class A+
28 kWh
18 W
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K, 7500K, 10000K, 5700K
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
HDCP, 72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, LED edgelight system, stand lock, Dell Custom Color, Full HD wide-viewing angle (WVA), BFR/PVC-free, Energy Gauge, Energy Saver, 96% sRGB (CIE 1931) colour gamut, Premium Panel Guarantee, Wi-Fi Direct, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, arsenic-free glass, Factory Calibration Report, Dell Easy Arrange, Screencast
53.91 cm x 18.5 cm x 35.58 cm - with stand
5.12 kg
HDMI , USB 3.0 upstream (Type B) , 4 x USB 3.0 downstream (Type A) , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, portrait / landscape mode, VESA interface support, 1 USB 3.0 charging port, Dell Soundbar mounting slots
Cable management cover
1 x SuperSpeed USB cable - USB Type A to B , 1 x HDMI cable
Mounting Kit
Optional
Security Slot Type
Kensington security slot
60 Watt
Power Consumption Stand by
3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.91 cm - depth: 18.5 cm - height: 35.58 cm - weight: 5.12 kg , Without stand - width: 53.91 cm - depth: 4.56 cm - height: 32.11 cm - weight: 3.28 kg
ENERGY STAR Certified
10 - 80% (non-condensing)
