Dell U2415 24.1" 1920x1200 6ms HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BPVYWS00 Mfr#: 210-AEVC
Diagonal Size: 24.1in
Max Resolution: 1920 x 1200
Response Time: 6ms
Interfaces: DisplayPort, HDMI, Mini DisplayPort, Mobile High-Definition Link (MHL)
More than 50 in stock
£179.27 ex VAT
£215.12 inc VAT
Revel in the superior screen performance of the Dell UltraSharp 24 monitor, loaded with premium features for an exceptional viewing experience, without the premium price tag.
Position your monitor to comfortably fit the way you work with a full range of tilt, pivot, swivel and height adjustments along with easy connections to your PC and peripherals.
Your Dell UltraSharp 24 Monitor - U2415 is designed to be pixel perfect. That's why if you find even just one bright pixel, we'll replace it under the Premium Panel Guarantee.
  • World-class screen performance
  • Outstanding usability and connectivity
  • Reliable and eco-efficient
  • Environmentally-conscious design
    Made with eco-friendly materials, the U2415 is BFR/PVC-free (excluding external cables) and has arsenic-free glass and a mercury-free LED panel. Enhanced power management with PowerNap enables the Dell Display Manager to either dim the monitor to the minimum brightness level or put it into sleep mode when it is not in use.
Dell UltraSharp U2415 - LED monitor - 24.1" - with 3-years Premium Panel Exchange service
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
26 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
6 ms (grey-to-grey); 19 ms (black-to-white)
Colour Support
16.8 million colours
Input Connectors
2xHDMI (MHL), DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
53.22 cm x 20.5 cm x 40.29 cm
6.35 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TCO Displays
3-year warranty
Bundled with
Display Type
Energy Class
Class A+
26 kWh
Diagonal Size
24.1"
Viewable Size
24.1"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, sharpness, saturation, gamma correction, rotation, input select, colour temperature, hue, aspect control
LED edgelight system, stand lock, 99% sRGB colour gamut, Multi-Stream transport (MST), BFR/PVC-free, Energy Gauge, Energy Saver, Premium Panel Guarantee, 91% (CIE 1976) colour gamut, 76% (CIE 1931) colour gamut, High Bit Rate 2 (HBR2)
53.22 cm x 20.5 cm x 40.29 cm - with stand
6.35 kg
Bundled with
2 x MHL / HDMI , DisplayPort output (MST) , Mini DisplayPort , 5 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out , DisplayPort
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
115 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management
Stand, cable management cover
1 x Mini DisplayPort-DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
65 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 53.22 cm - depth: 20.5 cm - height: 40.29 cm - weight: 6.35 kg , Without stand - width: 53.22 cm - depth: 4.57 cm - height: 35.06 cm - weight: 4.25 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell U2415 24.1 Bundle deal on Dell U2415 24.1" 1920x1200 6ms HDMI DisplayPort USB IPS LED Monitor
£279.03
BPVY C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BPVY C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.37
BPVY C2G 10m Select High Speed HDMI with Ethernet In Stock £41.25
BPVY C2G 15m Select High Speed HDMI with Ethernet In Stock £55.88
BPVY C2G Pro HDMI to VGA Converter In Stock £51.51
BPVY C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Response Time: 6ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Dell
Price Range Ex VAT: 150 - 300
