Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
- Dell UltraSharp U2412M - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- 55.6 cm x 18.03 cm x 39.85 cm
- 5.73 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified EPEAT Gold
- Plug and Play, DDC/CI, EDID compatible
- Display Type
- Diagonal Size
- 24"
- Viewable Size
- 24"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 50 - 61 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Colour Temperature
- 5000K, 10000K
- Controls & Adjustments
- Brightness, contrast, colour temperature
- 72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver
- 55.6 cm x 18.03 cm x 39.85 cm - with stand
- 5.73 kg
- VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
- Tilt Angle
- -4/+21
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 115 mm
- VESA Mounting Interface
- Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, Dell Soundbar mounting slots
- Included Accessories
- Stand
- Cables Included
- 1 x DVI cable , 1 x VGA cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 72 Watt
- Power Consumption Stand by / Sleep
- 0.5 Watt
- 0.5 Watt
- 0.5 Watt
- Included Software
- Drivers & Utilities, PowerNap
- Dimensions & Weight Details
- Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
