Dell U2412M 24" 1920x1200 8ms VGA DVI-D DisplyPort LED IPS Monitor
Quicklinx: 97G3WS00 Mfr#: 860-10150
Diagonal Size: 24in
Max Resolution: 1920 x 1200
Response Time: 8ms
Speakers: [N/A]
Interfaces: DisplayPort, DVI, VGA (HD-15)
More than 50 in stock
£126.87 ex VAT
£152.24 inc VAT
Enjoy widescreen performance, any way you want it. With a 24" 16:10 panel, IPS technology and LED backlight, the U2412M provides a brilliant view, plus amazing adjustability to suit any style.
Dell UltraSharp U2412M - LED monitor - 24"
LED-backlit LCD monitor - 24"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1920 x 1200 at 60 Hz
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
55.6 cm x 18.03 cm x 39.85 cm
5.73 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Plug and Play, DDC/CI, EDID compatible
Display Type
Diagonal Size
24"
Viewable Size
24"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
50 - 61 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Colour Temperature
5000K, 10000K
Controls & Adjustments
Brightness, contrast, colour temperature
72% (CIE 1931) colour gamut, 82% (CIE 1976) colour gamut, LED edgelight system, PowerNap, Dynamic Dimming, stand lock, Energy Saver
55.6 cm x 18.03 cm x 39.85 cm - with stand
5.73 kg
VGA , DVI-D , DisplayPort , USB 2.0 upstream (Type B) , 4 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-4/+21
Swivel Angle
90
Rotation Angle
90
Height Adjustment
115 mm
VESA Mounting Interface
Security lock slot (cable lock sold separately), Dell Energy Smart, LED indicator, integrated cable management, portrait / landscape mode, Dell Soundbar mounting slots
Stand
1 x DVI cable , 1 x VGA cable , 1 x USB cable
Security Slot Type
Kensington security slot
72 Watt
Power Consumption Stand by / Sleep
0.5 Watt
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Included Software
Drivers & Utilities, PowerNap
Dimensions & Weight Details
Without stand - width: 55.6 cm - depth: 6.49 cm - height: 36.16 cm - weight: 3.97 kg , With stand - width: 55.6 cm - depth: 18.03 cm - height: 39.85 cm - weight: 5.73 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell U2412M 24 Bundle deal on Dell U2412M 24" 1920x1200 8ms VGA DVI-D DisplyPort LED IPS Monitor
£226.04
Diagonal Size: 24in
Response Time: 8ms
Speakers: [N/A]
Interfaces: DVI
Interfaces: VGA (HD-15)
Brand: Dell
Stock Status: Clearance
Price Range Ex VAT: 100 - 150
