The Dell SonicWALL TZ 215 is the highest-performing, most secure Unified Threat Management (UTM) firewall available today in its price point. It provides full deep packet inspection (DPI) without diminishing performance, thus eliminating network bottlenecks that other products introduce, while enabling businesses to realize increased productivity gains.
Designed for small businesses, distributed enterprises, branch offices and retail deployments, the TZ 215 elegantly integrates the most effective anti-malware, intrusion prevention, URL filtering into a single solution, driving down cost and complexity. The TZ 215 adds application intelligence and control to ensure bandwidth for critical applications, while throttling non-productive ones. It speeds troubleshooting and forensics of real-time and historic data, using drill-down visualization and Application Traffic Analytics to provide deep insight into bandwidth utilization and security threats. Advanced networking features include multiple ISP failover and load balancing, optional dual-band secure wireless, IPSec VPN support, network segmentation and PCI compliance capabilities. The TZ 215 is the only UTM firewall with a native VPN remote access client for iOS, Google Android, Windows, Mac OS and Linux that supports Clean VPN, which decontaminates threats from VPN traffic. The TZ 215 is the most trusted, reliable and easy-to-use security platform on the market.
High-performance security engine
High-performance security engine uses patented Reassembly-Free Deep Packet Inspection technology to examine traffic simultaneously across all ports without introducing latency to the network. -
Integrated intrusion prevention
Integrated intrusion prevention protects against a comprehensive array of network-based application-layer exploits that target both servers and client machines on the network. -
Advanced IPSec and SSL VPN
Advanced IPSec and SSL VPN connectivity options provide easy-to-use, secure, high-speed office-to-office and client-to-office remote access. -
Streamlined GUI and advanced management
Streamlined GUI and advanced management ease deployment and configuration through intuitive set-up wizards and a powerful web interface. -
Application intelligence, control and visualization
Application intelligence, control and visualization offer real-time categorization of application traffic by user, delivering insight into the network for quick diagnosis and reaction to potential issues. -
Dual-band wireless
Dual-band wireless provides integrated 802.11 a/b/g/n secure wireless access for network clients over the 2.4 GHz and the 5 GHz spectrums, and is perfect for retail and office environments. -
Content/URL filtering
Content/URL filtering helps organizations and educational institutions enforce their acceptable-use policies and protect against inappropriate, illegal and dangerous web content. -
SonicWall comprehensive anti-spam service
SonicWall comprehensive anti-spam service utilizes real-time sender IP reputation analysis and cloud-based advanced content management techniques to remove spam, phishing and virus-laden messages from inbound SMTP-based emails before they reach the network. -
Multiple security zones
Multiple security zones provide network segregation with distinct security policies for each network segment. -
WAN/ISP redundancy and failover
WAN/ISP redundancy and failover increases network availability by seamlessly transitioning between multiple ISP connections in case of failure. -
Comprehensive centralized management
Comprehensive centralized management using the SonicWall Global Management System (GMS) provides award-winning tools for simplified configuration, enforcement and reporting of global security policies, VPN and services, all from a central location.
- SonicWall TZ 215 Wireless-N - security appliance - Wi-Fi
- Security appliance
- Form Factor
- External
- RAM
- 512 MB
- Flash Memory
- 32 MB
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Stateful throughput: 500 Mbps , Gateway anti-virus throughput: 70 Mbps , IPS throughput: 110 Mbps , Unified Threat Management (UTM) throughput: 60 Mbps , Firewall throughput (IMIX): 110 Mbps , VPN throughput (3DES/AES): 130 Mbps , Connection rate: 1800 connections per second
- Capacity
- Connection / user qty: 48000 , Maximum number of access points: 16 , VPN tunnels (site-to-site): 15 , SSL VPN peers: 2 , Nodes: unlimited , DPI connections: 32000 , Authenticated users (internal database): 150
- VoIP Protocols
- SIP, H.323 v3, H.323 v4, H.323 v1, H.323 v2, H.323 v5
- Power
- AC 120/230 V (50/60 Hz)
- 26.7 cm x 18.1 cm x 3.8 cm
- 0.97 kg
- 26.7 cm
- 18.1 cm
- 3.8 cm
- 0.97 kg
Processor / Memory / Storage
- RAM
- 512 MB
- Flash Memory
- 32 MB
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP, IPSec, PPPoE, DHCP
- Routing Protocol
- OSPF, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, HTTP, HTTPS, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Capacity
- Firewall protection, routing, NAT support, VPN support, PAT support, load balancing, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, antivirus analysis, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), DDos attack prevention, anti-spam protection, IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, bandwidth control, anti-spyware protection, NetFlow
- Encryption Algorithm
- DES, Triple DES, MD5, SHA-1, PEAP, TTLS, TKIP, WPA, WPA2, WPA-PSK, 128-bit AES, 256-bit AES
- Authentication Method
- RADIUS, LDAP, Active Directory, XAUTH authentication
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n
IP Telephony
- VoIP Protocols
Aerial
- Antenna
- External detachable
- Antenna Qty
- 3
- Gain Level
- 5 dBi
- 7 x 1000Base-T - RJ-45 , 1 x management , 2 x USB - Type A
- FCC Class A certified, UL, TUV GS, VCCI, C-Tick, ICSA Firewall certified, cUL, NOM, CB, FIPS 140-2 Level 2, MIC, RoHS, WEEE, EAL 4+, VPNC certified, IPv6 Ready
- Power Device
- External power adapter
- Voltage Required
- 15 Watt
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
