The Dell 15-inch Slipcase keeps your system protected, while the slim, lightweight design is easy to carry. The exterior of the case features a weather-resistant nylon and non-slip bottom for added stability. A quick-access pocket provides additional storage for your phone, keys and other small accessories. Retractable handles add versatility and allow you to carry the case anywhere you go. It is designed specifically for 15-inch Latitude Ultrabooks and notebooks.
Versatile protection for 15-inch laptops
Keep your laptop safe during travel with the Dell 15-inch Slipcase, which has a sleek, portable design that makes it easy to take anywhere. The versatile, high-quality case guards against scuffs, scratches and dust, and it offers an extra layer of protection when stored within another bag. Convenient retractable handles add versatility and make it easier to carry. -
Mobile, lightweight design
Ideal for users on the go, the slipcase has a slender and stylish profile designed for easy portability. The slipcase is lightweight and easy to take on short trips and long journeys. -
Weather-resistant nylon construction
Durable nylon construction protects your laptop from water and other potentially damaging elements. A non-slip bottom offers extra security and stability. -
Zippered, soft-lined interior
Your laptop will glide easily into the soft interior compartment. The slipcase is zippered to keep your system secure. -
Easy-access pocket
The slipcase includes a zippered quick-access pocket for storing additional items, such as keys, phone and wallet. -
Retractable handles let you change things up to suit your travel needs. Leave the handles extended when you use the case by itself, or retract them when transporting the case in another bag.
- Dell Slip Case - notebook carrying case
- Product Type
- Notebook carrying case
- Black
- 36.8 cm x 39.4 cm x 3.8 cm
- 0.41 kg
- Notebook Compatibility
- 15"
- Zippered
- Carrying Strap
- Hand grip
- Designed For
- Inspiron 15 3542, 15 3543, 15 3551, 15 3555, 15 5547, 15 5548, 15 7548, 5555, 5558, 5559, 7568; Latitude 3540, 3550, 3570, E5450, E5540, E5550, E5570, E6540; Precision 5510, 7510, M3800; Vostro 15 3546, 15 3549, 3558, 3559; XPS 15 (9530)
- Product Type
- 36.8 cm
- 39.4 cm
- 3.8 cm
- 0.41 kg
- 15"
- Zippered
- Carrying Strap
- Hand grip
- Black
- Designed For
- Dell Inspiron 15 3542, 15 3543, 15 3551, 15 3555, 15 5547, 15 5548, 15 7548, 5555, 5558, 5559, 7568 , Dell Latitude 3540, 3550, 3570, E5450, E5540, E5550, E5570, E6540 , Dell Precision 5510, 7510, M3800 , Dell Vostro 15 3546, 15 3549, 3558, 3559 , Dell XPS 15 (9530)
