Dell Slim DW316 USB External DVD Drive
Quicklinx: BWH7WS00 Mfr#: 784-BBBI
More than 50 In Stock
£35.58 ex VAT
£42.69 inc VAT
The Dell External USB Slim DVD +/ - RW Optical Drive is a plug and play disc burning and disc playing solution that you can use with a USB port.
Dell Slim DW316 - DVD±RW (±R DL) / DVD-RAM drive - USB 2.0 - external
DVD±RW (±R DL) / DVD-RAM drive - external
USB 2.0
14.4 cm x 13.75 cm x 1.4 cm
200 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Buffer Underrun Protection
Automatic Buffer Under Run Error Protection Technology
Media Load Type
Tray
USB 2.0
14.4 cm
13.75 cm
1.4 cm
200 g
Optical Storage
Read Speed
24x (CD) / 8x (DVD)
Write Speed
Supported Media Formats
CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, DVD-Video, DVD-Audio, Super Video CD, Super Audio CD Hybrid Disc
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, M-DISC
Media Load Type
Tray
Buffer Size
0.75 MB
Emergency disc eject hole, Active Optimum Power Control (AOPC), CPRM support
1 x USB 2.0
1 x USB cable - external - 60 cm
MTBF
150,000 hour(s)
Plug and Play
Software Included
CyberLink Media Suite CD
5 °C
15 - 85% (non-condensing)
Sound Emission
50 dBA
