Dell Sliding Rails Without Cable Management
Quicklinx: DFFXWS00 Mfr#: 770-BBRG
Device Type: Laptop
Stock Status: In Stock, Used Stock
Hurry, only 3 left in stock!
£76.65 ex VAT
£91.98 inc VAT
Dell ReadyRails Sliding Rails without Cable Management Arm. Rack slide rail kit for PowerEdge T320, T420, T430
Dell ReadyRails Sliding Rails without Cable Management Arm rack slide rail kit
Rack slide rail kit
PowerEdge T320, T330, T420, T430
Rack slide rail kit
Dell PowerEdge T320, T330, T420, T430
Dell Sliding Rails Without Cable Management Bundle deal on Dell Sliding Rails Without Cable Management
£176.41
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DFFX 038597
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £10.00
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Laptop
Brand: Dell
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
