Product
Brand
Dell Simple E-Port II With USB V3.0 Includes Power Cable
Quicklinx: CVJSWS00 Mfr#: 331-6307
More than 50 in stock
£81.18 ex VAT
£97.41 inc VAT
The USB 3.0 E-Port Replicator from Dell is a space-saving port replicator suitable for home and office environment which enables connection to your desk peripherals. This docking station includes a latest USB 3.0 technology enabled by Intel in Ivy Bridge. It has replaced the 2 USB 2.0 connectors with the USB 3.0. Plus, the Display Port 1.2 adds the ability to daisy chain displays (4 displays via 1 connector). Also it offers an adaptor complexity reduction. This product has been tested and validated on Dell systems. It is supported by Dell Technical Support when used with a Dell system. Please note this is the EU version.
Dell E-Port Replicator - port replicator
Port replicator
20 cm x 17 cm x 5.36 cm
780 g
Power adapter - external 130 Watt
Latitude E4200, E4300, E4310, E5250, E5270, E5400, E5410, E5420, E5430, E5440, E5450, E5460, E5470, E5500, E5510, E5520, E5530, E5540, E5550, E5570, E6220, E6230, E6320, E6330, E6400, E6410, E6420, E6430, E6430S, E6440, E6500, E6510, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
Port replicator
20 cm
17 cm
5.36 cm
780 g
1 x display / video - DisplayPort , 1 x display / video - DVI-Digital - 18+1 pin digital DVI (Single-Link) , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 3 x USB 2.0 - 4 pin USB Type A , 1 x network - RJ-45 , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - output - mini-phone stereo 3.5 mm
K-lock security slot
Power Provided
130 Watt
Dell Latitude E4200, E4300, E4310, E5250, E5270, E5400, E5410, E5420, E5430, E5440, E5450, E5460, E5470, E5500, E5510, E5520, E5530, E5540, E5550, E5570, E6220, E6230, E6320, E6330, E6400, E6400 ATG, E6400 XFR, E6410, E6410 ATG, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6500, E6510, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
Brand: Dell
Price Range Ex VAT: 50 - 100
