Dell Simple E-Port 2 With USB V3.0 Port
Quicklinx: 8THFWS00 Mfr#: 452-11429
Maximize your workspace with the Dell E-Port II Replicator. This E-Port Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices.
Dell E-Port II Simple - port replicator
Port replicator
20 cm x 17 cm x 5.37 cm
780 g
United Kingdom, Ireland
Power adapter - external 130 Watt Power Provided
Latitude 2120, 6430u, E5250, E5270, E5420, E5430, E5440, E5450, E5520, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470, XT3
Port replicator
20 cm
17 cm
5.37 cm
780 g
1 x headphones - output - mini-phone 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 3 x USB 2.0 - 4 pin USB Type A , 1 x monitor stand port
Power Provided
130 Watt
Dell Latitude 2120, 6430u, E5250, E5270, E5420, E5430, E5440, E5450, E5520, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6420 ATG, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470, XT3
8THF C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
