Lose yourself in the immersive experience of an elegantly designed 27-inch curved monitor with thin bezels and superb sound.
Simply stylish and sturdy
Sporting the thinnest borders on a 27" curved monitor, a solid base and covered in a sleek piano black finish, this monitor fits ideally in any home environment. -
A gorgeous view
The Dell 27-inch curved monitor offers great viewing comfort with its "wrap around" view, drawing you closer into the action and engaging you with its rich, powerful audio. -
One display for many devices
Connect to a multitude of secondary devices via a wide range of ports.
- Dell SE2716H - LED monitor - curved - Full HD (1080p) - 27" - with 3-Years Advance Exchange Service
- LED-backlit LCD monitor - 27"
- Energy Class
- Class A
- Energy Consumption per Year
- 36 kWh
- Power Consumption (On mode)
- 24.4 W
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1 / 8000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- 2xHDMI(MHL), VGA
- Tilt
- Screen Coating
- Anti-glare, 2H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 61.65 cm x 17.615 cm x 45.779 cm
- 5.96 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, WEEE, CECP
- 3-year warranty
- Bundled with
- 3-Years Advance Exchange Service
- Display Type
- Energy Class
- Class A
- 36 kWh
- Diagonal Size
- 27"
- Curved Screen
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.3114 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, phase
- Flicker Free technology, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
- Black
- 61.65 cm x 17.615 cm x 45.779 cm - with stand
- 5.96 kg
- Bundled with
Audio
- Speakers
- 2 x MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 24.4 W
- Power Consumption (Typical)
- 62 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 61.65 cm - depth: 7.128 cm - height: 36.62 cm - weight: 4.96 kg , With stand - width: 61.65 cm - depth: 17.615 cm - height: 45.779 cm - weight: 5.96 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
