Your basket is empty
Dell SE2716H 27" 1920x1080 6ms VGA HDMI Curved LED Monitor
Quicklinx: BPVWWS00 Mfr#: 210-AFZQ
Lose yourself in the immersive experience of an elegantly designed 27-inch curved monitor with thin bezels and superb sound.
Dell SE2716H - LED monitor - curved - Full HD (1080p) - 27" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24.4 W
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI(MHL), VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 2H Hard Coating
61.65 cm x 17.615 cm x 45.779 cm
5.96 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, WEEE, CECP, TCO Displays
3 years warranty
Bundled with
Display Type
Energy Class
Class A
36 kWh
24.4 W
Diagonal Size
27"
Viewable Size
27"
Curved Screen
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.3114 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, phase
72% (CIE 1931) colour gamut, 85% (CIE 1976) colour gamut, Flicker Free technology, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
61.65 cm x 17.615 cm x 45.779 cm - with stand
5.96 kg
Bundled with
Audio
Speakers
2 x MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-5/+21
Stand
1 x HDMI cable
62 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 61.65 cm - depth: 7.128 cm - height: 36.62 cm - weight: 4.96 kg , With stand - width: 61.65 cm - depth: 17.615 cm - height: 45.779 cm - weight: 5.96 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BPVW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BPVW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.73
BPVW C2G 5m Select High Speed HDMI with Ethernet In Stock £15.61
BPVW C2G 10m Select High Speed HDMI with Ethernet In Stock £29.98
BPVW C2G 15m Select High Speed HDMI with Ethernet In Stock £40.60
BPVW C2G Pro HDMI to VGA Converter In Stock £46.06
BPVW C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
