Dell SE2216H 21.5" 1920x1080 12ms VGA HDMI LED Monitor
Quicklinx: BPVPWS00 Mfr#: 210-AFZX
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 12ms
Interfaces: HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£78.00 ex VAT
£93.60 inc VAT
With the expanded viewing area provided by an improved bezel, the Dell 22 Monitor offers an affordable, sleek design for everyday computing.
  • Stylish design
    Enjoy the elegance of thin, glossy bezels, a sturdy base, and easy to use buttons.
  • Video quality
    Optimize your entertainment experience with rich and vibrant colors across wide viewing angles in Full HD resolution screen.
Dell SE2216H - LED monitor - Full HD (1080p) - 22" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
12 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
50.62 cm x 17.99 cm x 39.57 cm
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, CECP, EDID compatible
3-year warranty
Bundled with
Display Type
Energy Class
Class A
26 kWh
18 W
Diagonal Size
22"
Viewable Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.24795 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, clock, hue, aspect control
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, 84% (CIE 1976) colour gamut, integrated cable management, Flicker Free technology, BFR/PVC-free, Energy Gauge
50.62 cm x 17.99 cm x 39.57 cm - with stand
Bundled with
HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+21
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x VGA cable
Security Slot Type
Kensington security slot
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 50.62 cm - depth: 17.99 cm - height: 39.57 cm , Without stand - width: 50.62 cm - depth: 5.47 cm - height: 30.27 cm - weight: 2.78 kg
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Dell SE2216H 21.5 Bundle deal on Dell SE2216H 21.5" 1920x1080 12ms VGA HDMI LED Monitor
£177.17
BPVP C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BPVP C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.43
BPVP C2G 5m Select High Speed HDMI with Ethernet In Stock £21.43
BPVP C2G 10m Select High Speed HDMI with Ethernet In Stock £41.18
BPVP C2G 15m Select High Speed HDMI with Ethernet In Stock £55.29
BPVP C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 22in
Response Time: 12ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 50 - 100
