From classrooms to conference rooms, the S560T offers versatility and user-friendly features so you can keep audiences enthralled and interacting.
Fast setup, user-friendly compatibility, and wireless options make it easy to connect and start projecting from different devices.
Engage audiences with multi-touch, interactive presentations in Full HD resolution, ideal for group collaboration.
Massive screen, multi-touch collaboration
From classrooms to conference rooms, the S560T offers versatility and user-friendly features so you can keep audiences enthralled and interacting. -
Simple setup, convenient connections
Fast setup, user-friendly compatibility, and wireless options make it easy to connect and start projecting from different devices. -
Interactive, collaborative, built to impress
- Dell S560T - DLP projector
- DLP projector - 1080p
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 1800:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, composite video (PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 320 Watt
- 38.3 cm x 31.8 cm x 10.3 cm
- 4.7 kg
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3400 ANSI lumens
- Contrast Ratio
- 1800:1
- Image Size
- 206 cm - 254 cm
- Projection Distance
- 0.446 m - 0.558 m
- Throw Ratio
- 0.25:1
- Resolution
- 16:9
- Colour Support
- Bulb type
- 260 Watt
- Bulb life cycle
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- HDMI, composite video, RGB
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x HDMI input - 19 pin HDMI Type A , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x audio line-out - mini-phone stereo 3.5 mm , 2 x audio line-out - RCA x 2 , 1 x audio line-out - mini-phone mono 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Remote control, touch unit, 2 x passive pens, touch unit base plate kit
- Cables Included
- 1 x VGA cable - 5 m , 1 x mini-USB to USB cable - 5 m
- Power Source
- AC
- Voltage Required
- 320 Watt
- Power Consumption Stand by
- 0.5 Watt
- 38.3 cm
- 31.8 cm
- 10.3 cm
- 4.7 kg
- 5 °C
- 40 °C
- 0 - 80%
- Sound Emission
- 36 dBA
- Sound Emission (Economic Mode)
- 32 dBA
