Hold your attention with shadow free 3D projections with the S320wi projector featuring interactive and network functionality. Place the S320wi as close as to the projection surface. It's Short throw projection enables shadow free images which amazes your audience with the 3D-capability of the S320wi. The S320wi features an easy to use top load lamp replacement design whcih keeps cost low with a long lamp life in normal mode. Stay flexible with advanced interactive, wireless and network-management features. It provides HDMI port which lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR. Make a bold statement with amazing 3D imagery when you present with the S320wi projector.
Get close
Place the S320wi projector as close as 16" to the projection surface. Reduce shadowy images with short-throw projection. -
Bring multimedia to life
An HDMI port lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR. -
Project in 3D
Make a bold statement with amazing 3D imagery when you present with the S320wi projector. -
Go interactive:
Encourage collaboration with interactive projection. The included pen interacts with nearly any software application and can be applied directly to the screen or from up to 29.5'away. -
Present wirelessly:
Project PC-free or from a wireless device using multimedia capability and wireless functionality. Multi-PC presentations, 4-to-1 split screen and audio projection help hold your audience's attention. -
Plug into the network
Project from any computer in your network, manage power consumption and update your S320wi projectors through your network. -
Help save energy
The S320wi features an easy-to-use top-load lamp-replacement design. Keep costs low with a long lamp life. -
Stay versatile
Program your start-up screen to display your logo. Front and rear projection capabilities keep you flexible.
- Dell S320wi - DLP projector - 3D - 802.11n wireless / LAN
- DLP projector
- 3D Capable
- Bundled Services
- 2 years Advanced Exchange Service
- Brightness
- 3000 lumens
- Contrast Ratio
- 2200:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC), IEEE 802.11n wireless / LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 305 Watt
- 28.8 cm x 22 cm x 9.2 cm
- 3.18 kg
- 2-year warranty
- DLP projector
- 3D Capable
- Bundled Services
- Networking
- 802.11b/g/n, Ethernet
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2200:1
- Image Size
- 80 cm - 762 cm
- Projection Distance
- 0.4 m - 3.81 m
- Throw Ratio
- 0.626:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 240 Watt
- Bulb life cycle
- USB host function, Split Screen, Crestron RoomView, Digital Zoom
Lens
- Lens Aperture
- F/2.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +37
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
- Integrated
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
- Included Accessories
- Wrist strap, Interactive Pen, remote control, 10 pen nibs
- Cables Included
- 1 x VGA cable , 1 x USB cable - USB Type A to B , 1 x USB cable - USB type A to mini B - 2 m , 1 x USB cable - USB type A to mini B - 5 m
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 305 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- Software Included
- Drivers & Utilities, INTERWRITE Workspace
- 28.8 cm
- 22 cm
- 9.2 cm
- 3.18 kg
- Limited warranty - replacement - 2 years - response time: next business day
- 5 °C
- 35 °C
- 0 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 31 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
