Dell S320WI XGA DLP 3000 Lumens Projector
Quicklinx: 973GWS00 Mfr#: 210-40960
Hold your attention with shadow free 3D projections with the S320wi projector featuring interactive and network functionality. Place the S320wi as close as to the projection surface. It's Short throw projection enables shadow free images which amazes your audience with the 3D-capability of the S320wi. The S320wi features an easy to use top load lamp replacement design whcih keeps cost low with a long lamp life in normal mode. Stay flexible with advanced interactive, wireless and network-management features. It provides HDMI port which lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR. Make a bold statement with amazing 3D imagery when you present with the S320wi projector.
  • Get close
    Place the S320wi projector as close as 16" to the projection surface. Reduce shadowy images with short-throw projection.
  • Bring multimedia to life
    An HDMI port lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR.
  • Project in 3D
  • Go interactive:
    Encourage collaboration with interactive projection. The included pen interacts with nearly any software application and can be applied directly to the screen or from up to 29.5'away.
  • Present wirelessly:
    Project PC-free or from a wireless device using multimedia capability and wireless functionality. Multi-PC presentations, 4-to-1 split screen and audio projection help hold your audience's attention.
  • Plug into the network
    Project from any computer in your network, manage power consumption and update your S320wi projectors through your network.
  • Help save energy
    The S320wi features an easy-to-use top-load lamp-replacement design. Keep costs low with a long lamp life.
  • Stay versatile
    Program your start-up screen to display your logo. Front and rear projection capabilities keep you flexible.
Dell S320wi - DLP projector - 3D - 802.11n wireless / LAN
DLP projector
3D Capable
Bundled Services
2 years Advanced Exchange Service
Brightness
3000 lumens
Contrast Ratio
2200:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC), IEEE 802.11n wireless / LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
305 Watt
28.8 cm x 22 cm x 9.2 cm
3.18 kg
DLP projector
3D Capable
Bundled Services
802.11b/g/n, Ethernet
Projector
Brightness
3000 lumens
Contrast Ratio
2200:1
Image Size
80 cm - 762 cm
Projection Distance
0.4 m - 3.81 m
Throw Ratio
0.626:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
240 Watt
Bulb life cycle
USB host function, Split Screen, Crestron RoomView, Digital Zoom
Lens
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +37
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n
Speakers
Integrated
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45
Wrist strap, Interactive Pen, remote control, 10 pen nibs
1 x VGA cable , 1 x USB cable - USB Type A to B , 1 x USB cable - USB type A to mini B - 2 m , 1 x USB cable - USB type A to mini B - 5 m
Security Features
Security lock slot (cable lock sold separately), password protection
305 Watt
Power Consumption Operational (Standby)
0.5 Watt
Software Included
Drivers & Utilities, INTERWRITE Workspace
28.8 cm
22 cm
9.2 cm
3.18 kg
Limited warranty - replacement - 2 years - response time: next business day
5 °C
35 °C
0 - 80%
Sound Emission
35 dBA
31 dBA
973G C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
