Make a bold statement with amazing 3D imagery when you present with the S320 projector. The S320 features an easy-to-use top-load lamp-replacement design and keeps costs low with a long lamp life.
Get close
Place the S320 projector as close as 16" to the projection surface. Reduce shadowy images with short-throw projection. -
Bring multimedia to life
An HDMI port lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR. -
Project in 3D
Make a bold statement with amazing 3D imagery when you present with the S320 projector. -
Present wirelessly
Multi-PC presentations, 4-to-1 split screen and audio projection3 help hold your audience's attention. -
Help save energy
The S320 features an easy-to-use top-load lamp-replacement design and keeps costs low with a long lamp life. -
Stay versatile
Program your start-up screen to display your logo. Front and rear projection capabilities keep you flexible.
- Dell S320 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3000 lumens
- Contrast Ratio
- 2200:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 305 Watt
- 28.8 cm x 22 cm x 9.2 cm
- 3.18 kg
- DLP projector
- 3D Capable
Projector
- Brightness
- 3000 lumens
- Contrast Ratio
- 2200:1
- Image Size
- 80 cm - 762 cm
- Projection Distance
- 0.4 m - 3.82 m
- Throw Ratio
- 0.626:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 240 Watt
- Bulb life cycle
- Short Throw Technology, Vivid Color Control
Lens
- Lens Aperture
- F/2.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +37
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 5 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B (management)
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- RoHS
- Voltage Required
- 305 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 28.8 cm
- 22 cm
- 9.2 cm
- 3.18 kg
- 5 °C
- 35 °C
- 0 - 80%
- Sound Emission
- 35 dBA
- Sound Emission (Economic Mode)
- 31 dBA
