Dell S320 XGA 3000 Lumens Projector
Quicklinx: 9068WS00 Mfr#: 210-40929
Make a bold statement with amazing 3D imagery when you present with the S320 projector. The S320 features an easy-to-use top-load lamp-replacement design and keeps costs low with a long lamp life.
  • Get close
    Place the S320 projector as close as 16" to the projection surface. Reduce shadowy images with short-throw projection.
  • Bring multimedia to life
    An HDMI port lets you project multimedia from your PC, DVD player, Blu-ray Disc player, gaming console or DVR.
  • Project in 3D
  • Present wirelessly
    Multi-PC presentations, 4-to-1 split screen and audio projection3 help hold your audience's attention.
  • Help save energy
  • Stay versatile
    Program your start-up screen to display your logo. Front and rear projection capabilities keep you flexible.
Dell S320 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Brightness
3000 lumens
Contrast Ratio
2200:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, SECAM, PAL, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
305 Watt
28.8 cm x 22 cm x 9.2 cm
3.18 kg
DLP projector
3D Capable
Projector
Brightness
3000 lumens
Contrast Ratio
2200:1
Image Size
80 cm - 762 cm
Projection Distance
0.4 m - 3.82 m
Throw Ratio
0.626:1
Uniformity
80 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
240 Watt
Bulb life cycle
Short Throw Technology, Vivid Color Control
Lens
Lens Aperture
F/2.8
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +37
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Output Power / Channel
5 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin D-Sub (DB-15) , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x HDMI input - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB - mini-USB Type B (management)
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
RoHS
305 Watt
Power Consumption Operational (Standby)
0.5 Watt
28.8 cm
22 cm
9.2 cm
3.18 kg
5 °C
35 °C
0 - 80%
Sound Emission
35 dBA
31 dBA
9068 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
