Ideal for small workgroups, the DellTM Smart Printer - S2810dn offers easy-to-use features, efficient performance and essential security at a low cost per page.
Efficient printing
Print large and complex files effortlessly with an impressive 1GB of internal memory and save time with print speeds of up to 35 ppm (letter/A4). -
Secure print release
Keep sensitive documents private using the Secure Print feature. Print jobs are password protected and released easily when a valid user PIN is entered on the convenient LCD control panel's 10-digit keypad. -
Private/Public Mail Box Print
Store print jobs such as forms and templates in the built-in memory and print them when required. Stored jobs are easily released via the printer control panel. -
Reduce effort and paper usage
Cut paper costs and save up to 50% on paper usage with automatic two-sided printing. -
Convenient mobile printing
Print directly from a variety of mobile devices with Dell Document Hub app. This printer also supports AirPrint and Google Cloud Print, so you can print from virtually anywhere. -
Easy printer monitoring
The Dell OpenManage Printer Manager (OMPM) utility makes it easy to manage your network printers. Dell OMPM also enables the creation of printer status reports and fast deployment and driver updates. -
Reduce PC software clutter
Streamline driver management with the Dell Open Printer Driver (OPD), designed to reduce the huge workload of driver deployment and setting changes. -
Essential security features
Protect your device, information and network from unauthorized access with SNMPv3 encryption, IPSec and Transport Layer Security (TLS) protocols.
- Dell S2810dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 12.3 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm) , Up to 35 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 22 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 24 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN
- RAM Installed (Max)
- 1 GB DDR3 SDRAM
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, Extensible Mark-up Language (XML), HBPL
- Media Type
- Envelopes, labels, plain paper, recycled paper, cover paper, thin paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 40000 pages
- Recommended Monthly Volume
- 500 - 3000 pages
- Networking
- Print server
- System Requirements
- Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), SUSE Linux Enterprise Desktop 11 (32/64-bit), Ubuntu 12.04 LTS (64-bit), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple OS X 10.9 Mavericks, Ubuntu 12.04 LTS, Apple MacOS X 10.10, Red Hat Enterprise Linux Desktop 6 (32/64 bits)
- 1-year warranty
- 41 cm x 43.8 cm x 27.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0, LAN
- 1200 x 1200 dpi
- Media Handling
RAM
- 1 GB
- Technology / Form Factor
- DDR3 SDRAM
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 216 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) , 1 x automatic - 50 sheets - 215.9 x 355.6 mm
Duty Cycle
- 40000 pages
- 500 - 3000 pages
- Networking
- Print server
- Connections
- 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 1 x toner cartridge (black)
- GS, RoHS, WEEE
- Security Slot Type
- Kensington security slot
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Power Consumption Stand by
- 44 Watt
- Power Consumption Sleep
- 7 Watt
- OS Required
- Limited warranty - 1 year
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
- 41 cm
- 43.8 cm
- 27.3 cm
- 12.3 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
