Enjoy unrivaled clarity on a 27" 4K UHD monitor with USB-C connectivity - one cable lets you transfer video, audio and data, along with power delivery.
A stunning setup
Bring modern elegance to any space with the stunning Platinum Silver finish and a subtle textured back that gives your monitor a unique look. Plus, high functionality meets superb style with a three-sided ultrathin bezel design that allows you to see more with less distraction on this 27" screen. -
A superior screen
Experience 4 times more screen detail than FHD with the unrivaled clarity and vibrant color of UHD (3840 x 2160) resolution with HDR support. And In-Plane Switching (IPS) technology together with 99% sRGB color coverage lets you see extraordinary colors across a wide viewing angle. -
Comfort comes first
Customize your views with a height-adjustable stand and a monitor that tilts, swivels and pivots so you look your best and feel your best during work sessions or movie binges. -
Versatile connectivity
Easily charge and connect your laptop with USB-C connectivity and 65W of power delivery. This single-cable solution reduces cable clutter for a clutter-free desktop and transmits power, video, audio and data - all at once. -
Perfect ports
Charging and connecting your storage devices, mobile phones and other peripherals just got easier with a conveniently placed, quick-access USB 3.2 Gen 1 Type-A port. -
Engaging audio
Turn your monitor into an entertainment center with dual 3W integrated speakers. -
Seamless switching
Built-in dual HDMI ports keep your devices always plugged in and let you effortlessly switch between streaming and console gaming. -
More ways to multitask
Stay organized between applications, emails and windows on one screen using Dell Easy Arrange. You can also view multiple types of content from two different PC sources at once with Picture-by-Picture (PBP) or opt for Picture-in-Picture (PIP), which enables you to watch two images at once. -
Leisure gaming
Smooth, tear-free experience with AMD FreeSync technology, featuring up to 60Hz refresh rate. -
Easy on the eyes
This TÜV-certified monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to help reduce eye fatigue even over extended viewing - like your next movie marathon. -
Energy conservation
Save energy when your monitor is not in use with PowerNap, a feature that dims or puts your monitor to sleep when it's not in use.
- Dell S2722QC - LED monitor - 4K - 27" - HDR
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/704920
- Energy Class
- Class F
- Adaptive-Sync Technology
- AMD FreeSync
- USB 3.2 Gen 1/USB-C hub, USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 4 ms (grey-to-grey extreme), 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- 2xHDMI, USB-C
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare 3H hardness
- Voltage
- AC 100-240 V (50/60 Hz)
- Platinum silver
- Dimensions (WxDxH) - with stand (lowest position)
- 61.16 cm x 17.47 cm x 40.01 cm
- 7.1 kg
- Carbon Footprint
- 638 kg carbon emissions
- TUV, RoHS, BFR-free, DisplayPort 1.4, PVC-free
- Bundled Services
- 3 years Advanced Exchange Basic Warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 27"
- AMD FreeSync
- Built-in Devices
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 24 - 76 Hz
- Horizontal Refresh Rate
- 10 - 137 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED edgelight backlight
- Picture by picture, Flicker Free technology, Mercury free, arsenic-free glass, Dell Easy Arrange, Dell ComfortView, Picture-in-Picture, 3-sided bezeless
- Platinum silver
- 61.16 cm x 17.47 cm x 40.01 cm - with stand (lowest position)
- 7.1 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- 2 x HDMI , USB-C 3.2 Gen 1 upstream/DisplayPort 1.4 Alt Mode (power up to 65W) , USB 3.2 Gen 1 downstream , USB 3.2 Gen 1 downstream with Battery Charging 1.2 , Audio line-out
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 60
- Rotation Angle
- 180
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
- 1 x USB-C 3.2 Gen 2 cable - 1 m
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 24.8 kWh/1000h
- Power Consumption (Max)
- 155 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.2 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.16 cm - depth: 17.472 cm - height: 40.005 cm - weight: 7.1 kg , Without stand - width: 61.16 cm - depth: 5.543 cm - height: 36.464 cm - weight: 5.37 kg
- Shipping Weight
- 9.79 kg
Sustainability Information
- Carbon Footprint
- Total CF/unit Standard Deviation (kg CO2e)
- 167
- Manufacturing (kg CO2e)
- 369.19
- Logistics (kg CO2e)
- 47.99
- Use (kg CO2e)
- 215.47
- EOL (kg CO2e)
- 5.54
- Total Carbon w/o Use Phase (kg CO2e)
- 422.53
- PAIA Version
- 1.3.2, 2022
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Accessories (1)
Dell Dual Monitor Stand - MDS19 | In Stock | £169.04 |
Other bundles (2)
Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black | In Stock | £34.21 |
Dell KM5221WBKB-INT DELL PRO WIRELESS KB/MSE -KM5221W US | In Stock | £35.35 |
