Immerse yourself in widescreen clarity and superb audio with a dependable multimedia monitor that connects you seamlessly to the entertainment you love.
Enhanced home entertainment
Enjoy rich built-in audio, vivid widescreen viewing and a virtually borderless display. -
View and connect your way
Customize your desktop with flexible mounting possibilities, and stream movies and music from your tablet or smartphone. -
A breathtaking audio and video experience
Enrich your home computing experience with engaging multimedia and entertainment features. -
Crystal-clear visuals
Amped-up audio, seamless widescreen viewing on a virtually borderless monitor are great for any home environment. -
More realism, more fun
178° / 178° ultra-wide viewing angle on a clear 23.8" Full HD 1920x1080p screen will definitely astound you. -
Break down borders
Create a seamless multi-monitor display at home with an ultra-thin bezel width. -
Consistent, accurate color
View your media sharp and clear with an optimal color gamut for unrivaled visual richness. -
Sounds like a winner
Enjoy crisp, rich audio from your monitor with dual 3W speakers. Plus, with HDMI (MHL) ports, you can listen to music streamed right from your smartphone or tablet. -
Plug in to what you love
Stream audio and video from your tablet or smartphone, or display content on your larger monitor screen, with the HDMI (MHL) port. Plus, conveniently charge your handheld device at the same time. -
Go full-tilt
Easily customize to your preferred viewing angle by tilting 5° forward or 21° backward.
- Dell S2415H - LED monitor - Full HD (1080p) - 24" - with 3-Years Advanced Exchange Warranty
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A+
- Energy Consumption per Year
- 24 kWh
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 6 ms (overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 85% (CIE 1976)
- Input Connectors
- HDMI (MHL), VGA
- Tilt
- Screen Coating
- 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.91 cm x 18 cm x 40.46 cm
- Environmental Standards
- ENERGY STAR Qualified
- DDC/CI, RoHS, CECP
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Warranty
- Display Type
- Energy Class
- Class A+
- 24 kWh
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 6 ms (overdrive)
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- 3H Hard Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
- Glare, ultra wide viewing angle, LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
- Black
- 53.91 cm x 18 cm x 40.46 cm - with stand
- Bundled with
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
- Tilt
- Tilt Angle
- -6/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Included Accessories
- Stand, cable management cover
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 36 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- Without stand - width: 53.91 cm - depth: 4.59 cm - height: 32.11 cm - weight: 3.24 kg , With stand - width: 53.91 cm - depth: 18 cm - height: 40.46 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
