Dell S2415H 23.8" 1920x1080 6ms VGA HDMI IPS LED Monitor
Quicklinx: BPVKWS00 Mfr#: 210-AEVW
Immerse yourself in widescreen clarity and superb audio with a dependable multimedia monitor that connects you seamlessly to the entertainment you love.
  • Enhanced home entertainment
    Enjoy rich built-in audio, vivid widescreen viewing and a virtually borderless display.
  • View and connect your way
    Customize your desktop with flexible mounting possibilities, and stream movies and music from your tablet or smartphone.
  • A breathtaking audio and video experience
    Enrich your home computing experience with engaging multimedia and entertainment features.
  • Crystal-clear visuals
    Amped-up audio, seamless widescreen viewing on a virtually borderless monitor are great for any home environment.
  • More realism, more fun
    178° / 178° ultra-wide viewing angle on a clear 23.8" Full HD 1920x1080p screen will definitely astound you.
  • Break down borders
    Create a seamless multi-monitor display at home with an ultra-thin bezel width.
  • Consistent, accurate color
    View your media sharp and clear with an optimal color gamut for unrivaled visual richness.
  • Sounds like a winner
    Enjoy crisp, rich audio from your monitor with dual 3W speakers. Plus, with HDMI (MHL) ports, you can listen to music streamed right from your smartphone or tablet.
  • Plug in to what you love
    Stream audio and video from your tablet or smartphone, or display content on your larger monitor screen, with the HDMI (MHL) port. Plus, conveniently charge your handheld device at the same time.
  • Go full-tilt
    Easily customize to your preferred viewing angle by tilting 5° forward or 21° backward.
Dell S2415H - LED monitor - Full HD (1080p) - 24" - with 3-Years Advanced Exchange Warranty
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
24 kWh
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 8000000:1 (dynamic)
Response Time
6 ms (overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 85% (CIE 1976)
Input Connectors
HDMI (MHL), VGA
Display Position Adjustments
Tilt
Screen Coating
3H Hard Coating
Voltage
53.91 cm x 18 cm x 40.46 cm
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, CECP
3-year warranty
Bundled with
Display Type
Energy Class
Class A+
24 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
6 ms (overdrive)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
3H Hard Coating
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, sharpness, saturation, input select, phase, hue, aspect control
Glare, ultra wide viewing angle, LED edgelight system, stand lock, BFR/PVC-free, Energy Gauge, Energy Saver, Mercury free, arsenic-free glass
53.91 cm x 18 cm x 40.46 cm - with stand
Bundled with
Audio
Speakers - stereo
Output Power / Channel
3 Watt
MHL / HDMI , VGA , Headphones , Audio line-in
Mechanical
Tilt
Tilt Angle
-6/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
Stand, cable management cover
1 x HDMI cable
DDC/CI, RoHS, CECP
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
36 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
Without stand - width: 53.91 cm - depth: 4.59 cm - height: 32.11 cm - weight: 3.24 kg , With stand - width: 53.91 cm - depth: 18 cm - height: 40.46 cm
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BPVK C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
