With the expanded viewing area provided by an improved ultra-thin bezel, the Dell 23 Monitor offers a sleek, premium look and exceptional home entertainment experience.
Added elegance
Glossy, ultra-thin bezels, a classic black piano finish, and an aluminum painted riser create an elegant, modern design perfect for any home environment. -
Easy, intuitive access
Intuitive capacitive touch buttons on the bottom bezel offer a sleek and seamless finish. -
Sturdy stand
Easily tilt your monitor to your preferred viewing angle with the robust stand. -
Maximum viewing area
Get the most out of your 23" (58.42cm) viewing area with bezels almost half as thin as their predecessor. -
Impressive screen performance
Experience rich, accurate and consistent colors across a 178° ultra-wide viewing angle in Full HD 1920 x 1080 display. -
Superb clarity
Minimize reflections with a sleek, remarkably clear screen. -
Engaging audio
Dual 3W integrated speakers create the perfect audio complement to your viewing experience. -
Plug and view
Get easy compatibility with both legacy and future-ready PCs via VGA and HDMI connectivity. -
Reduced environmental footprint
The Dell 23 Monitor features PowerNap that reduces screen brightness or puts the monitor in sleep mode when it's not in use.
- Dell S2316H - LED monitor - Full HD (1080p) - 23" - with 3-Years Advanced Exchange Warranty
- LED-backlit LCD monitor - 23"
- Energy Class
- Class A
- Energy Consumption per Year
- 34 kWh
- Power Consumption (On mode)
- 23 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 8000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Colour Gamut
- 72% (CIE 1931), 82% (CIE 1976)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 52.07 cm x 17.99 cm x 40.42 cm
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI
- 3-year warranty
- Bundled with
- 3-Years Advanced Exchange Warranty
- Display Type
- Energy Class
- Class A
- 34 kWh
- Diagonal Size
- 23"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.265 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Glossy, LED edgelight system, adjustable LED power indicator, BFR/PVC-free, Energy Gauge, Energy Saver
- Black
- 52.07 cm x 17.99 cm x 40.42 cm - with stand
- Bundled with
Audio
- Speakers - stereo
- Output Power / Channel
- 3 Watt
- HDMI , VGA , Audio line-in , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+21
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 23 W
- Power Consumption (Typical)
- 34 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 52.07 cm - depth: 17.99 cm - height: 40.42 cm , Without stand - width: 52.07 cm - depth: 5.42 cm - height: 31.16 cm - weight: 2.9 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
