Flexible and user-friendly for work, school or fun. The Dell 21.5" touch monitor offers you 10-point touch capability with outstanding clarity and usability in a clean, efficient design.
Exceptional usability
Designed to encourage collaboration and give productivity a boost, the Dell 21.5" touch monitor offers a high level of user flexibility for work, school or entertainment. -
Natural touch and superb image clarity
Tap, slide, swipe, turn, pinch and stretch with your fingers. The multi-touch capability is simple and intuitive when used with recognizing up to 10 touch points at once. -
Efficient design
Conceived with a high priority on environmental efficiency, the Dell 21.5" touch monitor features low power consumption and environment-conscious materials.
- Dell S2240T - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
- LED-backlit LCD monitor - 22" - touchscreen
- Energy Class
- Class A
- Touch-screen, USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 8000000:1 (dynamic)
- Response Time
- 12 ms (overdrive)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% (CIE 1931), 84% (CIE 1976)
- Input Connectors
- HDMI, DVI-D, VGA
- Tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 52.25 cm x 20.57 cm x 37.08 cm
- 5.1 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Plug and Play, DDC/CI
- 3-year warranty
- Bundled with
- 3-Years Advance Exchange Service
- Display Type
- Energy Class
- Class A
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Brightness w/touchscreen
- 280 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- 12 ms (overdrive)
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 148.5 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
- OSD Languages
- Chinese (simplified), English, German, French, Spanish, Japanese
- LED edgelight system, Dynamic Dimming, Energy Gauge, Energy Saver, glove touch mode
- Black
- 52.25 cm x 20.57 cm x 37.08 cm - with stand
- 5.1 kg
- Bundled with
Input
- Touch-screen - touchscreen
- Movement Detection Technology
- Projected capacitive
- Movement Resolution
- 25 ppi
- VGA (HD-15) , HDMI , DVI-D , USB 2.0 upstream , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- +10/+60
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, VESA interface support
- Included Accessories
- Stand, cleaning cloth, touch fastener strap
- Cables Included
- 1 x HDMI cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- Included Software
- Drivers & Utilities, Dell Display Manager
- Dimensions & Weight Details
- With stand - width: 52.25 cm - depth: 20.57 cm - height: 37.08 cm - weight: 5.1 kg , Without stand - width: 52.25 cm - depth: 4.12 cm - height: 31.89 cm - weight: 3.4 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
