Dell S2240T 21.5" 1920x1080 12ms VGA DVI HDMI LED Monitor
Quicklinx: BVZ3WS00 Mfr#: 210-AGID
Flexible and user-friendly for work, school or fun. The Dell 21.5" touch monitor offers you 10-point touch capability with outstanding clarity and usability in a clean, efficient design.
  • Exceptional usability
    Designed to encourage collaboration and give productivity a boost, the Dell 21.5" touch monitor offers a high level of user flexibility for work, school or entertainment.
  • Natural touch and superb image clarity
    Tap, slide, swipe, turn, pinch and stretch with your fingers. The multi-touch capability is simple and intuitive when used with recognizing up to 10 touch points at once.
  • Efficient design
    Conceived with a high priority on environmental efficiency, the Dell 21.5" touch monitor features low power consumption and environment-conscious materials.
Dell S2240T - LED monitor - Full HD (1080p) - 22" - with 3-Years Advance Exchange Service
LED-backlit LCD monitor - 22" - touchscreen
Energy Class
Class A
Touch-screen, USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 8000000:1 (dynamic)
Response Time
12 ms (overdrive)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1931), 84% (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
52.25 cm x 20.57 cm x 37.08 cm
5.1 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI
3-year warranty
Bundled with
Display Type
Energy Class
Class A
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 2.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Brightness w/touchscreen
280 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
Response Time
12 ms (overdrive)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Video Bandwidth
148.5 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, sharpness, saturation, input select, colour temperature, phase, hue, aspect control
OSD Languages
Chinese (simplified), English, German, French, Spanish, Japanese
LED edgelight system, Dynamic Dimming, Energy Gauge, Energy Saver, glove touch mode
52.25 cm x 20.57 cm x 37.08 cm - with stand
5.1 kg
Bundled with
Input
Touch-screen - touchscreen
Movement Detection Technology
Projected capacitive
Movement Resolution
25 ppi
VGA (HD-15) , HDMI , DVI-D , USB 2.0 upstream , Audio line-out
Mechanical
Tilt
Tilt Angle
+10/+60
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Dell Energy Smart, integrated cable management, VESA interface support
Stand, cleaning cloth, touch fastener strap
1 x HDMI cable , 1 x USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
30 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Included Software
Drivers & Utilities, Dell Display Manager
Dimensions & Weight Details
With stand - width: 52.25 cm - depth: 20.57 cm - height: 37.08 cm - weight: 5.1 kg , Without stand - width: 52.25 cm - depth: 4.12 cm - height: 31.89 cm - weight: 3.4 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
BVZ3 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
