Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity. -
Flexible viewing features
The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort. -
Excellent screen clarity
Every detail is bright and clear with the crispness of LED backlighting. -
Color clarity and consistency across an ultra-wide viewing angle
The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio. -
Energy-efficient design
With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
- Dell P2014H - LED monitor - 20"
- LED-backlit LCD monitor - 20"
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 1600 x 900 at 60 Hz
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 8 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 83%
- Input Connectors
- DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 47.05 cm x 18 cm x 35.42 cm
- 3.2 kg
- Localisation
- United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- 3-year warranty
- Display Type
- Diagonal Size
- 20"
- Viewable Size
- 19.5"
- Built-in Devices
- USB Hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.271 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 83%
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- HDCP
- Black
- 47.05 cm x 18 cm x 35.42 cm - with stand
- 3.2 kg
- DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 2.0 downstream
Mechanical
- Height Adjustment
- 130 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Included Accessories
- Stand
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
- Localisation
- United Kingdom
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Sleep
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 3.2 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
