Product
Dell Professional P2014H 49.4cm(19.5 INCH) LED monitor VGA D
Quicklinx: 95T5WS00 Mfr#: 858-BBBR
Bright, clear and comfortable to view monitor. Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity possibilities.
  • Bright, clear and comfortable to view
    Help boost productivity at work and enrich entertainment at home in beautiful HD with adjustable viewing features and enhanced connectivity.
  • Flexible viewing features
    The Dell 20 monitor - P2014H adjusts to comfortably fit the way you work and play. Tilt, pivot, swivel and adjust the height of your monitor to maximize viewing comfort.
  • Excellent screen clarity
    Every detail is bright and clear with the crispness of LED backlighting.
  • Color clarity and consistency across an ultra-wide viewing angle
    The in-plane switching technology offers clear images with consistent and accurate colors across a wide 16:9 aspect ratio.
  • Energy-efficient design
    With 20 W normal-operation power consumption (typical) and less than 0.3 W power consumption in active-off mode, the P2014H can help keep your energy costs down.
Dell P2014H - LED monitor - 20"
LED-backlit LCD monitor - 20"
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 2000000:1 (dynamic)
Response Time
8 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
47.05 cm x 18 cm x 35.42 cm
3.2 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
TCO Displays
3 years warranty
Display Type
Diagonal Size
20"
Viewable Size
19.5"
Built-in Devices
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1600 x 900 at 60 Hz
Pixel Pitch
0.271 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
8 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
83% colour gamut, HDCP
47.05 cm x 18 cm x 35.42 cm - with stand
3.2 kg
DVI-D (HDCP) , DisplayPort , VGA , USB upstream , 3 x USB 2.0 downstream
Mechanical
Height Adjustment
130 mm
Flat Panel Mount Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
Stand
1 x DisplayPort cable , 1 x USB cable , 1 x VGA cable
TCO Displays
United Kingdom
Power Supply
Internal
20 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 47.05 cm - depth: 18 cm - height: 35.42 cm - weight: 3.2 kg , Without stand - width: 47.05 cm - depth: 4.65 cm - height: 27.29 cm - weight: 2.48 kg
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
95T5 C2G HDMI to DisplayPort Adapter Converter In Stock £37.46
95T5 C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.65
95T5 C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.72
95T5 C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
95T5 C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.32
95T5 C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.20
95T5 C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.75
95T5 C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.89
