The Dell Pro 24 Plus QHD Monitor P2425D is designed to enhance productivity and provide a visual experience. With a 23.8-inch viewable screen and a native resolution of 2560 x 1440, this monitor delivers crisp and clear images with a vibrant color spectrum made possible by 16.7 million colors and 99% sRGB color coverage. The monitor's LED backlight technology ensures brightness levels of up to 350 cd/m², along with a contrast ratio of 1500:1, making it ideal for both work and entertainment. Additionally, the anti-glare coating allows comfortable viewing in various lighting conditions, while the flicker-free panel and Low Blue Light technology help reduce eye strain during extended use. With versatile ergonomic adjustments, including height, swivel, pivot, and tilt features, users can customize their viewing experience. The built-in USB 3.2 Gen 1 hub extends connectivity options, allowing for seamless integration with various devices. The monitor's design features a 3-sided bezeless display and integrated cable management to keep workspaces tidy. Certified with EPEAT Gold and ENERGY STAR, this monitor prioritizes environmental standards while delivering performance and style.
- Dell Pro Plus P2425D - LED monitor - QHD - 24"
- LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/2151579
- Energy Class
- Class E
- Power Consumption (On mode)
- 15.6 W
- USB 3.2 Gen 1 hub, USB PD 15 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 100 Hz
- Pixel Pitch
- 0.2058 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1
- Response Time
- 5 ms (grey-to-grey fast), 8 ms (grey-to-grey normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% sRGB (CIE 1931)
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 100-240 V (50/60 Hz)
- Dimensions (WxDxH) - with stand (highest position)
- 53.87 cm x 18.154 cm x 49.655 cm
- 5.08 kg
- Pricing Type
- BTO
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, TCO Certified, generation 10, for displays, ENERGY STAR Qualified EPEAT Gold
- Carbon Footprint
- 175 kg carbon emissions
- Plug and Play, RoHS, BFR-free, DisplayPort 1.4, HDCP 1.4, PVC-free, TUV Rheinland Eye Comfort Certification (4-star)
- Bundled Services
- 3 years Basic Hardware Service with Advanced Exchange after remote diagnosis
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Built-in Devices
- USB 3.2 Gen 1 hub
- USB Power Delivery
- 15 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2058 mm
- Pixel Per Inch
- 123
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1500:1
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 150 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- LED edgelight system, Mercury free, arsenic-free glass, Dell Easy Arrange, Wide Viewing Angle, Low Blue Light technology, 3-sided bezeless, Dell ComfortView Plus, flicker-free panel
- 53.87 cm x 18.154 cm x 49.655 cm - with stand (highest position)
- 5.08 kg
- DisplayPort 1.4 (HDCP 1.4) , HDMI (HDCP 1.4) , USB 3.2 Gen 1 upstream (Type B) , 3 x USB 3.2 Gen 1 downstream (Type A) , USB-C 3.2 downstream with Power Charging (power up to 15W)
Mechanical
- Tilt Angle
- -5/+21
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management, VESA interface support
- Cables Included
- 1 x DisplayPort 1.4 cable - DisplayPort to DisplayPort - 1.8 m , 1 x USB 3.2 Gen 1 upstream cable - USB Type A to B - 1.8 m
- Pricing Type
- BTO
- Security Slot Type
- Kensington security slot
- Input Voltage
- 15.6 W
- Power Consumption SDR (On mode)
- 16 kWh/1000h
- Power Consumption (Typical)
- 15.9 Watt
- Power Consumption (Max)
- 75 Watt
- Power Consumption Stand by
- 0.3 Watt
- 0.3 Watt
- Included Software
- Dell Display Manager
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.87 cm - depth: 18.154 cm - height: 36.4 cm - weight: 5.08 kg , With stand (highest position) - width: 53.87 cm - depth: 18.154 cm - height: 49.655 cm - weight: 5.08 kg , Without stand - width: 53.87 cm - depth: 4.974 cm - height: 31.525 cm - weight: 3.2 kg
- Shipping Weight
- 7.04 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Carbon Footprint
- Manufacturing (kg CO2e)
- 80.85
- Logistics (kg CO2e)
- 13.3
- Use (kg CO2e)
- 76.65
- EOL (kg CO2e)
- 4.2
- Total Carbon w/o Use Phase (kg CO2e)
- 98.35
- PAIA Version
- GaBi version 1
- Bundled Services
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
Dell Dual Monitor Stand - MDS19 | In Stock | £129.07 |
Dell Pro Plus P2425D 24" 2560x1440 5ms HDMI DisplayPort IPS LED Monitor
