Dell Pro 14 Plus Intel Core Ultra 7-268V 32GB 512GB SSD 14" Windows 11 Professional
Quicklinx: J5YHWS00 Mfr#: 969VR
Screen Size: 14in
Processor Model: 268V
Operating System: Windows 11 Pro
Hard Drive Capacity: 512GB
Graphics: Intel Arc Graphics 140V
  • IEEE 802.11n
£1,435.11 ex VAT
£1,722.13 inc VAT
The Dell Pro 14 Plus PB14250 is designed to enhance productivity with robust features and performance. It boasts a 14-inch Full HD Plus display, capable of resolutions up to 1920 x 1200, ensuring clear visuals and vibrant colors. The anti-glare IPS technology provides a wide viewing angle, making it suitable for collaborative work and media consumption. Alongside the impressive visual capability, the laptop integrates a powerful Intel Core Ultra 7 processor that supports multitasking with its 8-core design, reaching clock speeds of up to 5 GHz. The solid-state drive (SSD) with 512 GB capacity ensures quick boot-ups and rapid data access, significantly improving workflow efficiency. With capabilities such as ExpressCharge and advanced thermal management, this device is engineered to perform reliably in various environments while being environmentally conscious with ENERGY STAR certification and EPEAT Gold level compliance. The audio experience is enriched by dual noise-canceling microphones and stereo speakers, making video calls clearer and media playback enjoyable. The integrated RGB camera with Temporal Noise Reduction adds to the user experience, offering crisp images at 1080p resolution. For connectivity, it features multiple USB-C ports with Power Delivery, HDMI, and Bluetooth support, allowing seamless integration of peripherals and accessories. The combination of security features, including a fingerprint reader and TPM 2.0, ensures data protection and privacy for users. The Dell Pro 14 Plus PB14250 stands as a reliable companion for professionals seeking a balance of performance, portability, and security in their computing experience.
  • Exceptional visuals
    The 14-inch Full HD Plus display offers a native resolution of 1920 x 1200, delivering clarity and vibrant colors for all types of content, from professional documents to videos.
  • Powerful performance
    Powered by an Intel Core Ultra 7 processor with 8 cores and a maximum turbo speed of 5 GHz, this laptop is designed to handle demanding applications and multitasking.
  • Efficient storage solution
    The 512 GB SSD provides ample storage space and ensures fast boot times and quick access to files, enhancing overall productivity.
  • Robust audio capabilities
    Equipped with dual noise-canceling microphones and stereo speakers, the Dell Pro 14 Plus PB14250 improves the experience for video conferencing and multimedia playback.
  • Enhanced connectivity
    Multiple USB-C ports with Power Delivery, alongside HDMI, enable extensive connectivity options for a variety of peripherals, ensuring integration into any workstation.
Dell Pro 14 Plus PB14250 - Copilot+ PC - 14" - Intel Core Ultra 7 - 268V - vPro Enterprise - 32 GB RAM - 512 GB SSD
Notebook - Copilot+ PC
Operating System
Win 11 Pro - Dutch / English / French / German / Italian
Platform Technology
Intel vPro Enterprise
Intel Core Ultra 7 (Series 2) - 268V / 2.2 GHz, up to 5 GHz / 12 MB Cache
Neural Processor Unit (NPU)
Intel AI Boost - up to 48 TOPS
32 GB LPDDR5X SDRAM (provided memory is soldered)
Storage
512 GB SSD - NVMe
Display
14" 1920 x 1200 / Full HD Plus @ 60 Hz - 162 ppi
Graphics
Intel Arc Graphics 140V - up to 66 TOPS
Keyboard Backlight
Integrated Webcam
Bluetooth, NFC, 802.11a/b/g/n/ac/ax/be
3-cell
Security
Discrete Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader, contactless smart card reader
31.35 cm x 22.4 cm x 2.12 cm
1.53 kg
Pricing Type
Build To Stock (BTS)
Manufacturer Selling Program
Dell Smart Selection
Environmental Standards
ENERGY STAR Qualified EPEAT Gold, EPEAT Climate+
Carbon Footprint
108 kg carbon emissions
Bundled Services
1 Year Basic Onsite
Notebook
AI Level
Copilot+ PC
Operating System
Windows 11 Pro - Dutch / English / French / German / Italian
Processor / Chipset
CPU
Intel Core Ultra 7 (Series 2) 268V / 2.2 GHz
Max Turbo Speed
5 GHz
Number of Cores
8-core
Performance Cores
4
Efficient Cores
4
Cache
12 MB
Platform Technology
8 Threads
Intel AI Boost
NPU Performance Up To (TOPS)
48 TOPS
Total Processor Performance Up To (TOPS)
118 TOPS
AI Datatype Support on NPU
INT8
Sparsity Support
AI Software Frameworks Supported by NPU
DirectML, OpenVINO, WebNN, WindowsML, ONNX RT
Windows Studio Effects Support
RAM
32 GB (provided memory is soldered)
LPDDR5X SDRAM
Speed
4267 MHz
Rated Speed
4267 MHz
Storage
Main Storage
512 GB SSD M.2 2230 PCIe 4.0 - NVM Express (NVMe)
Display
14" - IPS
Resolution
1920 x 1200 (Full HD Plus)
V-Sync Rate at Max Res.
60 Hz
Widescreen
Pixel Density (ppi)
162
Image Aspect Ratio
16:10
Image Brightness
300 cd/m²
Horizontal Viewing Angle
+80 / -80
Vertical Viewing Angle
+80 / -80
Colour Gamut
45% NTSC
Anti-glare, Wide Viewing Angle, 35 ms response rate, 0.157 mm pixel pitch
Audio & Video
Graphics Processor
Camera
Yes - 2560 x 1440 (standard), 640 x 360 (infrared)
Resolution
5.2 Megapixel (standard), 0.23 Megapixel (infrared)
Image Sensor Type
CMOS
Video Resolutions
2560 x 1440
Frame Rate
30 frames per second
Camera Features
Face recognition, IR camera, IR presence detection camera, RGB camera, Temporal Noise Reduction, 86.6 degrees (IR camera), Express Sign-In, camera shutter
Sound
Stereo speakers, 2 digital microphones
Codec
CS42L43
Input
Keyboard, touchpad
Keyboard Backlight
Copilot key
Communications
Wireless
Wireless Controller
Intel WI-FI 7 BE201
Dual stream (2x2)
3-cell Lithium Ion
220 g
55 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
65 watt, 5/9/15/20 V
Connections & Expansion
Interfaces Details
HDMI , 2 x USB4 (supports Thunderbolt 4, DisplayPort 2.1 Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (PowerShare) , USB 3.2 Gen 1 , Headphone/microphone combo jack
Software
Software Included
Dell Additional Softwares, Activate your Microsoft 365 for a 30 day trial
Case Material
Aluminum
Security
ExpressCharge, ExpressChargeBoost, Dell ControlVault 3 +
Theft/Intrusion Protection
Security Slot Type
Wedge-shaped security slot
USB-C power adapter
FIPS 140-2, TCG Certified
Pricing Type
1.53 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
EPEAT Climate+
ENERGY STAR Certified
Carbon Footprint
Manufacturing (kg CO2e)
76.896
Logistics (kg CO2e)
4.536
Use (kg CO2e)
24.516
EOL (kg CO2e)
2.052
Total Carbon w/o Use Phase (kg CO2e)
83.48
PAIA Version
GaBi version 1, 2024
Bundled Services
1 Year Basic Onsite
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
110 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
160 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
Essential Accessories (2)
Get more from your purchase from one of our essential accessories
J5YH Dell Pro Dock WD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE In Stock £148.54
J5YH Dell Pro Smart Dock SD25 - docking station - USB-C - HDMI, 2 x DP, USB-C - 1GbE, 2.5GbE In Stock £206.78
Warranty Packs (2)
Protect your investment by taking out one of our great value warranty packs
J5YH Dell Upgrade from 1Y Basic Onsite to 3Y Basic Onsite - 2 years - 2nd/3rd year - on-site In Stock £60.54
J5YH Dell Upgrade from 1Y Basic Onsite to 3Y ProSupport - 3 years - on-site In Stock £153.31
Other bundles (29)
J5YH Dell Slim DW316 USB External DVD Drive In Stock £40.60
J5YH Dell MS116 Mouse Optical Wired USB Black For Lattitude In Stock £8.69
J5YH Dell KB216 Keyboard USB Black For Inspiron 17 5759, 3459 In Stock £12.80
J5YH Dell Dell KB-522 Wired Business Multimedia USB Keyboard - Black In Stock £23.31
J5YH Dell KB-813 Smart Card Reader In Stock £32.06
J5YH Dell Pro KM5221W Keyboard and Mouse Set - QWERTY - UK - Black In Stock £26.55
J5YH Dell Wireless Keyboard and Mouse KM7120W - UK - Titan Grey In Stock £44.32
J5YH Dell SB521A Magnetic Sound bar In Stock £30.78
J5YH Dell MS5120W Mobile Pro Wireless Mouse In Stock £26.00
J5YH Dell Premier Multi-Device KM7321W Wireless Keyboard and Mouse In Stock £44.78
J5YH Dell Dual Monitor Stand - MDS19 In Stock £129.07
J5YH Dell Multi-Device KB700 - Keyboard - wireless - 2.4 GHz, Bluetoot In Stock £48.55
J5YH Dell WEBCAM - WB3023 In Stock £47.02
J5YH Dell Dell Mobile Wireless Mouse - MS3320W - Black In Stock £15.38
J5YH Dell Dell Speakerphone SP3022 In Stock £63.32
J5YH Dell UltraSharp 24" 1920 x 1080 5 ms IPS In Stock £157.91
J5YH Dell 27" P2724DEB 2560x1440 5ms HDMI DisplayPort USB-C Video Conferencing Monitor In Stock £341.58
J5YH Dell P2225H 22" 1920x1080 5ms VGA HDMI DisplayPort LED Monitor In Stock £88.69
J5YH Dell P2425HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £165.88
J5YH Dell UltraSharp U2724D - LED monitor - QHD - 27" In Stock £278.61
J5YH Dell P2725H 27"1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £139.87
J5YH Dell P2425H 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £119.24
J5YH Dell P242524" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £135.97
J5YH Dell UltraSharp U2424HE 24" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £209.52
J5YH Dell UltraSharp U2725QE 27" 3840x2160 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £518.22
J5YH Dell P2725HE 27" 1920x1080 5ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £186.11
J5YH Dell Pro Plus P2725DE 27" 2560x1440 8ms HDMI DisplayPort USB-C IPS LED Monitor In Stock £256.26
J5YH Dell Pro E2425HSM 24" 1920x1080 5ms VGA HDMI DisplayPort IPS LED Monitor In Stock £87.77
J5YH Dell UltraSharp U2724DE 27" 2560x1440 5ms HDMI DisplayPort Thunderbolt 4 IPS LED Monitor In Stock £361.32
Screen Size: 14in
Brand: Dell
Price Range Ex VAT: £1000 - £1500
