Always on the go? No more worries about running out of battery power! You can power your laptop with this Lithium-ion battery from Dell. With large capacity, the battery lets you work seamlessly when you are on the move for business trips or vacations. This battery provides uninterrupted reliable performance you need to get the most out of your system. Lithium-ion batteries are longer lived than conventional batteries and do not require replacement as often.
- Dell Primary Battery - laptop battery - Li-Ion - 87 Wh
- Laptop battery
- Battery
- Lithium Ion 9-cell - 87 Wh
- Designed For
- Precision M4600, M4700, M6600, M6700
- Laptop battery
- Technology
- 9-cell Lithium Ion
- Capacity
- 87 Wh
- Designed For
- Dell Precision M4600, M4700, M6600, M6700
