Tower workstation in a compact design with expansion options. A new generation of performance.
Choose the Dell actively cooled PCIe SSD storage solution for the fastest and most reliable way to store your content, up to 180% faster than traditional SATA SSD storage.
Reduce the time spent loading or saving large data sets with software- or hardware-based RAID controllers for your hard drive, available on all Precision Workstations.
Quick Resource Locator (QRL): Model-specific QR codes located on the system allow you to quickly access detailed how-tos and troubleshoot hardware from your smartphone.
Powerful processors
Power through the most demanding, interactive applications quickly with incredible performance with processor series. The Dell Precision Tower 5810 delivers better performance for iterative design and prototyping. -
Powerful graphics and memory
The superb graphics deliver the muscle you need to run the most demanding software applications. Impressive graphics offer larger dedicated graphics memory for your large data sets. System memory is expandable using the latest DDR4 RDIMM memory technology. -
Certified for seamless reliability
ISV (Independent Software Vendor) certification means that the Dell Precision Workstations you purchase are tested to ensure the high-performance applications you rely on every day run smoothly. ISV certification is the result of precise engineering and rigorous testing to optimize performance and reliability to run leading industry applications for engineering, manufacturing, media, entertainment, healthcare, life sciences, oil, gas, economics and financial services. -
Improve productivity with Dell Precision Optimizer 2.0
Different applications have different system requirements. Let Dell Precision Optimizer 2.0 take the guesswork out of customizing settings by automatically adjusting Intel Hyper-Threading, number of CPU cores, graphics and power settings. Free with your Dell Precision, the Dell Precision Optimizer 2.0 automatically tunes your Workstation to run specific programs at the fastest speeds possible, enhancing productivity. The engineers have created profiles specifically for the applications you use, minimizing the need to customize settings according to each application. -
Maximize reliability with Reliable Memory Technology (RMT)
Dell's exclusive, patented Reliable Memory Technology (RMT) helps maximize uptime and ensure that your Workstations work as hard as you do. RMT works in conjunction with error-correcting code (ECC) memory to detect and correct memory errors in real time. RMT makes memory errors virtually nonexistent so that the bad memory is never revisited again and the DIMM can still be used. With a simple system reboot, RMT isolates the defective area in memory and hides it from the OS. -
Customizable management
Update once and update everywhere with Dell-unique Intel vPro extensions for remote BIOS management and hard drive wipe, even when systems are offline. -
Dell Client Command Suite
By building unique management capabilities into Dell Precision Workstations, Dell Client Command Suite provides free automation tools that help automate and streamline system deployment, monitoring and updating in complex IT environments. -
Seamless integration
Automation tools work with all management consoles and integrate seamlessly with Microsoft Systems Center 2012, allowing fewer steps to import drivers. -
Security and performance
Dell Precision Workstations feature best-in-class endpoint security solutions that include comprehensive encryption, advanced authentication and improved malware protection from a single source.
- Dell Precision Tower 5810 - mid tower - Xeon E5-1650V3 3.5 GHz - vPro - 16 GB - SSD 256 GB, HDD 500 GB
- Workstation - mid tower
- Platform Technology
- Intel vPro Platform
- Processor
- 1 x Intel Xeon E5-1650V3 / 3.5 GHz (, up to 3.8 GHz, (6-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 15 MB L3 Cache
- Cache Per Processor
- 15 MB
- RAM
- 16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB
- Hard Drive (2nd)
- HDD 500 GB - SATA - 7200 rpm
- Optical Storage
- DVD-Writer
- Graphics Controller
- NVIDIA Quadro K2200
- Video Memory
- 4 GB
- Networking
- GigE
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition
- Software Included
- Microsoft Office (Trial)
- Black
- 17.26 cm x 47.1 cm x 41.4 cm
- Pricing Type
- Build To Plan (BTP)
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 3 years - response time: next business day
- Workstation
- Product Form Factor
- Mid tower
- Black
Processor / Chipset
- CPU
- Intel Xeon E5-1650V3
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- L3 Cache - 15 MB
- 15 MB
RAM
- Installed Size
- 16 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 4 (empty)
- Registered
- Configuration Features
- 4 x 4 GB
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
Hard Drive (2nd)
- HDD
- Interface Class
- Serial ATA
- Capacity
- 1 x 500 GB
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Channel Qty
- 6
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Video Memory
- 4 GB
Audio Output
- High Definition Audio
Input Device
- Mouse (on selected markets only), keyboard (on selected markets only)
Mouse
- Mouse Name
- Dell MS116 USB Optical Mouse
- Technology
- Optical
- Ethernet Controller
- Intel I217
- Data Link Protocol
- Remote Wake Up, PXE support
- Bays
- 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line
- Slots
- 1 (total) / 0 (free) x CPU , 8 (total) / 4 (free) x DIMM 288-pin , 2 (total) / 1 (free) x PCIe 3.0 x16 - full-length , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length (x8 mode) , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length , 1 (total) / 1 (free) x PCI - full-length
- 6 x USB 2.0 (3 front, 3 rear) , 4 x USB 3.0 (1 front, 3 rear) , 1 x audio line-out/headphones , 1 x audio line-in/microphone , 1 x LAN (Gigabit Ethernet) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- GS, CECP
- Pricing Type
- Power supply
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 90%
Operating System / Software
- OS Provided
- Software
Sustainability Information
- ENERGY STAR Certified
- 17.26 cm
- 47.1 cm
- 41.4 cm
