Dell Precision 5530 Intel Core i7-8850H 16GB 256GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F2HBWS00 Mfr#: M46D5
  • Core i7
  • IEEE 802.11n
Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
  • Professional-grade graphics
    Boost performance of extreme graphics applications with next-generation professional graphics from NVIDIA. An intense graphics upgrade packed into an incredibly mobile design.
  • Expandable storage
    Access, transfer and store large 3D, video and multimedia files quickly and easily with SSD storage.
  • Revolutionary thermals
    This cooling system features dual fans, designed to improve airflow and keep your system cool under heavy workloads.
Dell Precision 5530 - 15.6" - Core i7 8850H - vPro - 16 GB RAM - 256 GB SSD
Mobile workstation
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Platform Technology
Intel vPro Platform
Intel Core i7 (8th Gen) 8850H / 2.6 GHz (4.3 GHz) / 9 MB Cache
16 GB DDR4 (1 x 16 GB)
Storage
256 GB SSD
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Input Device
Keyboard, touchpad
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Silver
35.7 cm x 23.5 cm x 1.7 cm
1.78 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - response time: next business day
Mobile workstation
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
CPU
Max Turbo Speed
4.3 GHz
Number of Cores
6-core
Cache
9 MB
64-bit Computing
Chipset
Mobile Intel CM246
Platform Technology
Intel vPro Platform
Intel Turbo Boost Technology 2.0
RAM
16 GB (1 x 16 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
2666 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD M.2 PCIe
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
Colour Gamut
72%
UltraSharp, Premium Panel Guarantee, Wide Viewing Angle
Audio & Video
Graphics Processor
NVIDIA Quadro P1000
Video Memory
4 GB GDDR5 SDRAM
Camera
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
66 degrees
Sound
Stereo speakers, dual array microphone
High Definition Audio, Wave MAXXAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-finger touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9260
Network Interface
Ethernet
3-cell Lithium Ion
56 Wh
AC Adapter
Input
Output
130 Watt, 19.5 V, 6.67 A
Connections & Expansion
USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , LAN (on supplied cable) , 2 x USB 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI
Memory Card Reader
Yes (SD Card)
Silver
Security
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
Power adapter, USB-C to Ethernet adapter
Pricing Type
Build To Plan (BTP)
1.78 kg
20 - 80% (non-condensing)
Shock Tolerance (operating)
140 g @ 2 ms
Shock Tolerance (non-operating)
160 g @ 2 ms
Vibration Tolerance (operating)
0.66 g @ RMS (random)
Vibration Tolerance (non-operating)
1.3 g @ RMS (random)
