Dell Precision 5530 Intel Core i7-8706G 16GB 512GB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: F2HHWS00 Mfr#: 2406R
Display Size: 15.6in
Processor Model: I7-8706G
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 16GB
Hard Drive Capacity: 512GB
  • Core i7
  • IEEE 802.11n
10 in stock
£1,844.57 ex VAT
£2,213.48 inc VAT
Experience unrestrained innovation with the small and light, premium-built Precision mobile workstations. Built with Intel Core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with the power that rivals your own ingenuity.
  • Views beyond limit, color beyond measure
    Turn heads wherever you go with an elegantly designed 2-in-1 mobile workstation engineered for ultra-mobile computing and graphics intensive programs.
  • Like a studio on-the-go
    Create works of art on a screen that supports familiar pen-based interactions like sketching, drawing, annotating and more. And with the ability to leverage keyboard shortcuts, projects can be completed all on one machine no matter where inspiration strikes.
  • Less border, more pixels
    Enjoy a next-gen 15.6" InfinityEdge screen that seems endless with an incredibly slim border - just 4.7mm wide. See every detail with stunning resolution for big, glorious, pinpoint-precise images.
  • Beautiful from any angle
    The anti-reflective screen combined with superior 400-nit brightness frees you to create even outdoors. Plus, the IGZO 4 panel provides a wider viewing angle, so you can share your screen without missing a thing.
  • Designed for creation
    Tablet mode allows you to sketch ideas, draw, take notes, and annotate content comfortably and naturally, directly on the surface. While stand/tent mode creates the ideal position to share and collaborate with multiple parties.
  • Advanced connectivity
    The two Thunderbolt 3 and two USB Type-C ports allow you to charge your 2-in-1, connect to and power multiple devices (including support for up to two 4K displays).
Dell Precision Mobile Workstation 5530 2-in-1 - 15.6" - Core i7 8706G - 16 GB RAM - 512 GB SSD - with 3-year ProSupport
Notebook - flip design
Operating System
Win 10 Pro 64-bit - Multilingual User Interface (MUI)
Intel Core i7 (8th Gen) 8706G / 3.1 GHz (4.1 GHz) / 8 MB Cache /
16 GB DDR4 (provided memory is soldered)
Storage
512 GB SSD NVMe, Class 40
Optical Drive
No optical drive
Display
15.6" LED backlight touchscreen 1920 x 1080 / Full HD
Graphics
AMD Radeon Pro WX Vega M GL
Video Memory
4 GB HBM2
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
6-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip
Silver
35.4 cm x 23.5 cm x 1.6 cm
2 kg
Pricing Type
Build To Plan (BTP)
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years
Bundled Services
3 Years Dell ProSupport
Operating System
Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Bundled Services
Processor / Chipset
CPU
Max Turbo Speed
4.1 GHz
Number of Cores
Quad-Core
Cache
8 MB
64-bit Computing
Chipset
Mobile Intel QM175
Platform Technology
Intel vPro Technology
Intel Turbo Boost Technology 2.0
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe), Class 40
Display
15.6"
LCD Backlight Technology
LED backlight
Touchscreen
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
400 cd/m²
UltraSharp, anti-glare, IGZO technology, Infinity Edge display, Wide Viewing Angle
Audio & Video
Graphics Processor
Video Memory
4 GB HBM2
Camera
Yes - 1280 x 720 (standard), 340 x 340 (infrared)
Resolution
0.92 Megapixel
Video Resolutions
1280 x 720
Frame Rate
30 frames per second
Camera Features
720p HD movie recording, IR camera, 2 x infrared emitters
Sound
Stereo speakers, array microphone
Codec
Realtek ALC3271
Wave MAXXAudio Pro
Audio Features
MaxxAudio Pro
Input
Keyboard, touchpad
Keyboard Backlight
Multi-gesture touch pad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 8265
6-cell Lithium Ion
75 Wh
AC Adapter
Input
Output
130 Watt, 20 V, 6.5 A
Connections & Expansion
2 x USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , 2 x USB-C/Thunderbolt 3 (Power Delivery) , Headphone/microphone combo jack
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office (Trial)
Silver
Security
Noise reduction, battery life Indicator, Dell Premium Active Pen magnets
Theft/Intrusion Protection
Security Slot Type
Noble Wedge security slot
USB-C power adapter
Pricing Type
Build To Plan (BTP)
2 kg
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
Shock Tolerance (operating)
105 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
Vibration Tolerance (operating)
0.26 g @ RMS (random)
Vibration Tolerance (non-operating)
1.37 g @ RMS (random)
Software applications
Dell Precision 5530 Intel Core i7-8706G 16GB 512GB SSD 15.6 Bundle deal on Dell Precision 5530 Intel Core i7-8706G 16GB 512GB SSD 15.6" Windows 10 Professional 64-bit
£1,943.74
Optical Storage: None
Graphics: AMD Radeon Pro WX Vega M GL
Hard Drive Type: SSD
Touchscreen: Yes
Type: Laptop
Brand: Dell
Price Range Ex VAT: 1500+
