Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
Professional-grade graphics
Boost performance of extreme graphics applications with next-generation professional graphics from NVIDIA. An intense graphics upgrade packed into an incredibly mobile design. -
Expandable storage
Access, transfer and store large 3D, video and multimedia files quickly and easily with SSD storage. -
Revolutionary thermals
This cooling system features dual fans, designed to improve airflow and keep your system cool under heavy workloads.
- Dell Precision 5530 - 15.6" - Core i7 8850H - vPro - 16 GB RAM - 256 GB SSD
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i7 (8th Gen) 8850H / 2.6 GHz (4.3 GHz) / 9 MB Cache
- Memory
- 16 GB DDR4 (1 x 16 GB)
- Storage
- 256 GB SSD
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P1000
- Video Memory
- 4 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Silver
- 35.7 cm x 23.5 cm x 1.7 cm
- 1.78 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - response time: next business day
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.3 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (1 x 16 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 PCIe
Display
- 15.6" - IPS
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Brightness
- 400 cd/m²
- Colour Gamut
- 72%
- UltraSharp, Premium Panel Guarantee, Wide Viewing Angle
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 66 degrees
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio, Wave MAXXAudio Pro
Input
- Multi-finger touchpad
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 9260
- Network Interface
- Ethernet
- Technology
- 3-cell Lithium Ion
- Capacity
- 56 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 130 Watt, 19.5 V, 6.67 A
Connections & Expansion
- USB-C 3.1 Gen 2 (supports Thunderbolt 3) (Power Delivery) , LAN (on supplied cable) , 2 x USB 3.1 Gen 1 (PowerShare) , Headphone/microphone combo jack , HDMI
- Memory Card Reader
- Yes (SD Card)
- Silver
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter, USB-C to Ethernet adapter
- Pricing Type
- 1.78 kg
- 0 °C
- 40 °C
- 20 - 80% (non-condensing)
- Shock Tolerance (operating)
- 140 g @ 2 ms
- Shock Tolerance (non-operating)
- 160 g @ 2 ms
- Vibration Tolerance (operating)
- 0.66 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.3 g @ RMS (random)
