The Dell Precision 3540 is a smaller, lighter and more accessible workstation. Built to empower productivity in CAD and other demanding applications.
Ground-breaking innovation
The Precision 3540 is all about mobility. It's made with premium materials and has outstanding battery life. -
Bigger productivity
The narrow-edge display gives you more screen real estate on your 15" (38 cm) mobile workstation which makes it easier to view CAD applications and heavy Excel spreadsheets. -
Brilliant performance
The Precision 3540 comes fully equipped with a powerful Intel Core processor, perfect for demanding CAD and heavy spreadsheets. -
Versatility at its finest
Stay connected to all the tools you need with ports that include Thunderbolt, HDMI, USB and more.
- Dell Precision 3540 - 15.6" - Core i5 8265U - 8 GB RAM - 256 GB SSD
- Product Type
- Mobile workstation
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
- Memory
- 8 GB DDR4
- Storage
- 256 GB SSD - NVMe
- Display
- 15.6" WLED 1920 x 1080 / Full HD @ 60 Hz - 141 ppi
- Graphics
- AMD Radeon Pro WX 2100
- Video Memory
- 2 GB GDDR5 SDRAM
- Input Device
- Keyboard, touchpad
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 35.91 cm x 23.625 cm x 2.2 cm
- 1.83 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - on-site
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.9 GHz
- Number of Cores
- Quad-Core
- Cache
- 6 MB
- 64-bit Computing
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM
- Speed
- 2400 MHz
- Rated Speed
- 2400 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
Storage
- Main Storage
- 256 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Pixel Density (ppi)
- 141
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, Wide Viewing Angle, ±80° horizontal viewing angle, ±80° vertical viewing angle
Audio & Video
- Graphics Processor
- Video Memory
- 2 GB GDDR5 SDRAM
- Camera
- Yes - HD
- Image Sensor Type
- CMOS
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- Fixed focus, 78.6 degrees, RGB camera
- Sound
- Stereo speakers, dual array microphone
- Codec
- Realtek ALC3254
- High Definition Audio
- Audio Features
- MaxxAudio Pro
Input
- Numeric Keypad
- Multi-finger touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Technology
- 3-cell Lithium Ion
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 90 Watt, 19.5 V, 4.62 A
Connections & Expansion
- 3 x USB 3.1 Gen 1 , LAN , USB-C 3.1 Gen 1 (supports Thunderbolt 3, DisplayPort Alt Mode) , Headphone/microphone combo jack , HDMI
- Memory Card Reader
- Yes (microSD)
Software
- Software Included
- Microsoft Office (Trial)
- Black
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 1.83 kg
- 0 °C
- 35 °C
- 10 - 80% (non-condensing)
- Shock Tolerance (operating)
- 105 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 40 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.26 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.37 g @ RMS (random)
