Experience unrestrained innovation with the thinner and lighter, premium-built Precision mobile workstations. Built with Intel 6-core processors, blazing-fast memory and professional graphics, the Precision mobile family is engineered with power that rivals your own ingenuity.
Small design, big performance
This small mobile workstation packs a powerful punch, with an enhanced design to bring your greatest ideas to life. -
Robust graphics
Master any visualization challenge in no time with next generation NIVIDIA Quadro professional graphics cards. -
Fit for your lifestyle
Designed with cable docking, this small and compact workstation can carry large projects wherever the job takes you. -
Connect with ease
Support for 4K video to an external monitor at 60 frames per second via HDMI 2.0 allows you to create and edit your work in perfect clarity.
- Dell Precision Mobile Workstation 3530 - 15.6" - Core i5 8300H - 8 GB RAM - 256 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - Multilingual User Interface (MUI)
- Processor
- Intel Core i5 (8th Gen) 8300H / 2.3 GHz (4 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD NVMe
- Optical Drive
- No optical drive
- Display
- 15.6" WLED 1920 x 1080 / Full HD
- Graphics
- NVIDIA Quadro P600
- Video Memory
- 4 GB GDDR5 SDRAM
- Keyboard Backlight
- Numeric Keypad
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac Wave 2, Bluetooth 5.0, Gigabit Ethernet
- Battery
- 4-cell
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, smart card reader
- Black
- 37.6 cm x 25.07 cm x 2.43 cm
- 2.03 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years - response time: next business day
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - Multilingual User Interface (MUI)
Processor / Chipset
- CPU
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- 64-bit Computing
- Chipset
- Mobile Intel CM246
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 32 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 2666 MHz
- Rated Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
- 15.6"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Anti-glare, 72% colour gamut, PremierColor technology, Wide Viewing Angle, ±85° horizontal viewing angle, ±85° vertical viewing angle
Audio & Video
- Graphics Processor
- Video Memory
- 4 GB GDDR5 SDRAM
- Camera
- Resolution
- 0.92 Megapixel
- Video Resolutions
- 1280 x 720
- Frame Rate
- 30 frames per second
- Camera Features
- 74 degrees
- Sound
- Stereo speakers, array microphone
- Codec
- Realtek ALC3246-CG
- High Definition Audio, Wave MAXXAudio Pro
Input
- Keyboard, touchpad
- Numeric Keypad
- Precision touchpad
Communications
- Wireless
- Wireless Controller
- Intel Wireless-AC 9560 - M.2 Card
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Intel I219-LM
- Wake-on-LAN (WOL)
- Technology
- 4-cell
- Capacity
- 68 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 130 Watt, 19.5 V, 6.67 A
Connections & Expansion
- USB-C/Thunderbolt 3/DisplayPort , LAN , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (PowerShare) , VGA , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, Memory Stick, MultiMediaCard, Memory Stick PRO-HG Duo, SDHC Card, SDXC Card, Memory Stick XC, SDXC UHS-II Card, SDXC UHS Card, Memory Stick PRO-HG)
- Black
- Security
- Microphone with noise-cancellation
- Theft/Intrusion Protection
- Security Slot Type
- Noble Wedge security slot
- Included Accessories
- Power adapter
- Pricing Type
- 2.03 kg
Get more from your purchase from one of our essential accessories
Dicota Privacy filter 2-Way for Laptop 15.6" Wide (16:9), magnetic | In Stock | £59.52 |
Dicota Privacy filter 2-Way for Laptop 15.6" Wide (16:9), self-adhesive | In Stock | £44.69 |
Dicota Privacy filter 4-Way for Laptop 15.6" Wide (16:9), self-adhesive | In Stock | £57.24 |
