Dell PowerEdge T640 Intel Xeon Silver 4214 16GB 240GB SSD
Quicklinx: FL12WS00 Mfr#: 07J4C
Case Style: Tower
Processor Type: Xeon Silver
Hard Disk Capacity: 240GB
Processor Speed: 2.2GHz
Installed Memory: 16GB
Hurry, only 2 left in stock!
£1,733.88 ex VAT
£2,080.65 inc VAT
The PowerEdge T640 is a versatile, powerhouse server ideal for mid-sized offices, remote sites and data centers. The T640 combines powerful performance and massive internal storage capacity in a rack or tower platform. Address a wide range of workloads and future-proof your data center with flexible storage, performance and I/O options.
Meet evolving business needs with the scalable business architecture of the PowerEdge T640. Accelerate demanding workloads and plan for future growth with cost-effective, in-server expansion.
Dell OpenManage intelligent automation enables you to spend less time on routine maintenance so you can focus on business-critical priorities.
A comprehensive, cyber-resilient architecture with security embedded into every server helps to protect your data.
  • Accelerate modern workloads with a scalable platform
  • Adapt and scale with greater versatility
  • Enhance productivity with intelligent automation
  • Protect your business with integrated security
Dell EMC PowerEdge T640 - tower - Xeon Silver 4214 2.2 GHz - 16 GB - 240 GB - no RAID
Server - tower
Bundled Services
3 Years Basic Onsite
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon Silver 4214 / 2.2 GHz (3.2 GHz) (12-core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
16.5 MB
Cache Per Processor
16.5 MB
RAM
16 GB (installed) / 768 GB (max) - DDR4 SDRAM
Storage Controller
RAID (Dell PERC H730P+)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
1 x SSD 240 GB (hot-swap)
Optical Storage
DVD-Writer
GigE, 10 GigE
Power Redundancy
Optional
OS Provided
No operating system
30.45 cm x 70.87 cm x 47.15 cm
Pricing Type
Build To Plan (BTP)
Server
Bundled Services
Product Form Factor
Tower - 5U
Server Scalability
2-way
Hot-Swap Bays Qty
16
Processor / Chipset
CPU
Max Turbo Speed
3.2 GHz
Number of Cores
12-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
16.5 MB
Cache Per Processor
16.5 MB
RAM
Installed Size
16 GB / 768 GB (max)
DDR4 SDRAM
Effective Memory Speed
2400 MHz
Rated Memory Speed
2933 MHz
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, dual rank
Configuration Features
1 x 16 GB
RAM Supported
3072 GB Load-Reduced , 768 GB registered , 192 GB Non-Volatile
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Storage Controller Name
Dell PERC H730P+
Buffer Size
2 GB
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x 10 Gigabit Ethernet
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
16 (total) / 15 (free) x hot-swap 2.5"
Slots
2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 3.0 x8 - full-length, full-height (x4 mode) , 1 PCIe 3.0 x8 - half-length, full-height (2 processors must be installed) , 1 PCIe 3.0 x8 - full-length, full-height (2 processors must be installed) , 2 PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 PCIe 3.0 x8 - full-length, full-height (x4 mode, 2 processors must be installed)
3 x USB 2.0 (1 front, 2 rear) , 5 x USB 3.0 (1 front, 4 rear) , 1 x management , 1 x VGA , 2 x LAN (10Gigabit Ethernet)
Bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
30.45 cm
70.87 cm
47.15 cm
10 °C
35 °C
10 - 80%
Case Style: Tower
Brand: Dell
Price Range Ex VAT: 1500+
