Drive a wide range of demanding workloads with a flexible server offering peak 2-socket performance and huge internal storage capacity.
Accelerate demanding workloads with the powerful and flexible PowerEdge T630 2-socket tower server, a member of the 13th generation of PowerEdge servers.
Expanded capacity, unprecedented capability: With support for up to 50 percent more hard drives than previous generations, the PowerEdge T630 brings new capabilities to small and medium businesses and remote offices running mail and messaging, medical imaging, server and desktop virtualization, and budget-conscious graphical rendering. Supporting up to 32 x 2.5" or 18 x 3.5" hard drives, the T630 can store more mailboxes of larger sizes can dramatically lower your cost per mailbox. Flexible storage configurations allow you to meet exacting workload requirements, while ample drive space allows for cost-effective, in-server expansion.
Manage your servers the way you want: individually, collectively, in-person, remotely or with your smartphone - it's your choice. Consistent administration and 3rd-party integration ensures seamless management of PowerEdge servers.
Administer systems from your smartphone, laptop or at the system with both local and remote management options.
Whether installed as a tower or rack-mounted server, the PowerEdge T630 is ready to drive your demanding workloads today and into the future. With its powerful and scalable performance, Fresh Air 2.0 compliance and library-quiet acoustics, it has the versatility to accelerate a wide range of demanding workloads.
Versatile and efficient performance
Drive rapid response times with the powerful processor E5-2600 v3 product family, DDR4 memory and seven I/O slots. -
With support for up to 50 percent more hard drives than previous generations, the PowerEdge T630 brings new capabilities to small and medium businesses and remote offices running mail and messaging, medical imaging, server and desktop virtualization, and budget-conscious graphical rendering. Supporting up to 32 x 2.5" or 18 x 3.5" hard drives, the T630 can store more mailboxes of larger sizes can dramatically lower your cost per mailbox. Flexible storage configurations allow you to meet exacting workload requirements, while ample drive space allows for cost-effective, in-server expansion. -
Fast storage, fast insights
Up to four NVMe Express Flash PCIe SSDs and the optional 12Gb PowerEdge RAID Controller (PERC9) make the PowerEdge T630 ideal for a wide range of IOPs-hungry workloads including database, enterprise resource planning (ERP) and decision support. For increased application acceleration, the T630 can take advantage of optional Dell Fluid Cache for SAN and SanDisk DAS Cache for even faster data access. In-server storage tiering and multi-mode RAID options also help optimize virtual storage for VMware vSAN and Microsoft Storage Spaces. -
Powerful GPU acceleration
From graphical rendering to implementing virtual desktops, support for up to four optional GPU accelerators enables additional performance and capability.
- Dell PowerEdge T630 - tower - Xeon E5-2603V4 1.7 GHz - 4 GB - HDD 1 TB
- Server - tower
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon E5-2603V4 / 1.7 GHz (6-core)
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 4 GB (installed) / 768 GB (max) - DDR4 SDRAM
- Storage Controller
- SATA (SATA 6Gb/s) (Dell PERC S130)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- HDD 1 TB (hot-swap) - SATA - 7200 rpm
- Optical Storage
- No optical drive
- Graphics Controller
- Matrox G200
- Video Memory
- 16 MB
- Networking
- GigE
- OS Provided
- No operating system
- Black
- 30.45 cm x 70.87 cm x 44.35 cm
- Pricing Type
- BTO
- Limited warranty - 3 years - response time: next business day
- Server
- Product Form Factor
- Tower - 5U
- 2-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon E5-2603V4
- Clock Speed
- 1.7 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 4 GB / 768 GB (max)
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 24 (Total) / 23 (empty)
- Registered, single rank
- Configuration Features
- 1 x 4 GB
Hard Drive
- HDD - hot-swap
- Capacity
- 1 x 1 TB
- Interface Type
- SATA
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- Dell PERC S130
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- No optical drive
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5720
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 8 Express (iDRAC8)
- Bays
- 8 (total) / 7 (free) x hot-swap 3.5"
- Slots
- 2 PCIe 3.0 x16 - full-length, full-height , 1 PCIe 2.0 x4 - full-length, full-height , 1 PCIe 3.0 x8 - half-length, full-height , 2 (total) / 1 (free) x CPU , 24 (total) / 23 (free) x DIMM 288-pin
- 4 x USB 2.0 , 3 x USB 3.0 (1 front, 2 rear) , 2 x VGA (1 front, 1 rear) , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC)
- Pricing Type
- BTO
- Power supply
- Power Provided
- 750 Watt
Operating System / Software
- OS Provided
- 30.45 cm
- 70.87 cm
- 44.35 cm
- 10 °C
- 35 °C
- 10 - 80%
