The PowerEdge T440 tower server delivers powerful 2-socket performance, expandability and quiet operation to your small to mid-sized business (SMB) and remote office/branch office (ROBO) sites. Outstanding efficiency helps you keep operating expenses in check as your requirements evolve.
Adapt and scale with an expandable, virtualization-ready platform
The PowerEdge T440 brings you flexibility with a rack-capable tower platform, short depth and quiet acoustics that are right for your office or data center. The T440 is an excellent fit for a wide range of office workloads, including work group collaboration and productivity applications, mail and messaging, file and print serving, and web serving. -
Rely on PowerEdge with integrated security
Every PowerEdge server is made with a cyber-resilient architecture, building security into all parts of a server's life cycle. The T440 uses security features so you can reliably and securely deliver the right data to where your customers are, no matter where they are.
- Dell EMC PowerEdge T440 - tower - Xeon Silver 4110 2.1 GHz - 8 GB - SSD 240 GB - with 3-year ProSupport
- Server - tower
- Bundled Services
- 3 Years ProSupport
- Height (Rack Units)
- 5U
- Server Scalability
- 2-way
- Processor
- 1 x Intel Xeon Silver 4110 / 2.1 GHz (3 GHz) (8-core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 11 MB
- Cache Per Processor
- 11 MB
- RAM
- 8 GB DDR4 SDRAM
- Storage Controller
- RAID (SAS 12Gb/s) (Dell PERC H330+)
- Server Storage Bays
- Hot-swap 3.5"
- Hard Drive
- SSD 240 GB (hot-swap)
- Optical Storage
- DVD-Writer
- Graphics Controller
- Matrox G200eR2
- Video Memory
- 16 MB
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- OS Provided
- No operating system
- Black
- 21.8 cm x 57.3636 cm x 47.1333 cm
- 29.5 kg
- Pricing Type
- Build To Plan (BTP)
- Limited warranty - 3 years
- Server
- Bundled Services
- Product Form Factor
- Tower - 5U
- Built-in Devices
- Status LCD
- 2-way
- Hot-Swap Bays Qty
- 8
- Black
Processor / Chipset
- CPU
- Intel Xeon Silver 4110 / 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 1
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
Cache Memory
- Installed Size
- 11 MB
- 11 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2667 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 15 (empty)
- Registered, single rank
- Configuration Features
- 1 x 8 GB
Hard Drive
- SSD - hot-swap
- Capacity
- 1 x 240 GB
Storage Controller
- 1 x RAID
- Controller Interface Type
- SAS 12Gb/s
- Storage Controller Name
- Dell PERC H330+
Optical Storage
- DVD-Writer DVD-Writer
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- Matrox G200eR2
- Video Memory
- 16 MB
- Video Interfaces
- VGA
- Ethernet Ports
- 2 x Gigabit Ethernet
- Data Link Protocol
- Remote Management Controller
- Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
- Bays
- 8 (total) / 7 (free) x hot-swap 3.5"
- Slots
- 2 PCIe 3.0 x4 - half-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height , 2 PCIe 3.0 x8 - half-length, full-height
- 5 x USB 2.0 - Type A (1 front, 4 rear) , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 1 x VGA (1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear)
- Included Accessories
- Bezel
- Pricing Type
- Power supply - hot-plug
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Installed Qty
- 1
- Max Supported Qty
- 2
- Nominal Voltage
- Power Provided
- 495 Watt
Operating System / Software
- OS Provided
- 21.8 cm
- 57.3636 cm
- 47.1333 cm
- 29.5 kg
- 10 °C
- 35 °C
- 10 - 80%
