Dell PowerEdge T440 Intel Xeon Bronze 310 8GB 240GB SSD
Quicklinx: F6NKWS00 Mfr#: NWHNV
Case Style: Tower
Processor Type: Xeon Bronze
Hard Disk Capacity: 240GB
Processor Speed: 1.7GHz
Installed Memory: 8GB
£1,122.51 ex VAT
£1,347.01 inc VAT
The PowerEdge T440 tower server delivers powerful 2-socket performance, expandability and quiet operation to your small to mid-sized business (SMB) and remote office/branch office (ROBO) sites. Outstanding efficiency helps you keep operating expenses in check as your requirements evolve.
  • Adapt and scale with an expandable, virtualization-ready platform
    The PowerEdge T440 brings you flexibility with a rack-capable tower platform, short depth and quiet acoustics that are right for your office or data center. The T440 is an excellent fit for a wide range of office workloads, including work group collaboration and productivity applications, mail and messaging, file and print serving, and web serving.
  • Rely on PowerEdge with integrated security
    Every PowerEdge server is made with a cyber-resilient architecture, building security into all parts of a server's life cycle. The T440 uses security features so you can reliably and securely deliver the right data to where your customers are, no matter where they are.
Dell EMC PowerEdge T440 - tower - Xeon Bronze 3106 1.7 GHz - 8 GB - 240 GB
Server - tower
Height (Rack Units)
5U
Server Scalability
2-way
1 x Intel Xeon Bronze 3106 / 1.7 GHz (8-core)
Cache Memory
11 MB
Cache Per Processor
11 MB
RAM
8 GB DDR4 SDRAM
Storage Controller
RAID (SAS 12Gb/s) (Dell PERC H330+)
Server Storage Bays
Hot-swap 3.5"
Hard Drive
1 x SSD 240 GB (hot-swap)
Optical Storage
No optical drive
Graphics Controller
Matrox G200eR2
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
21.8 cm x 57.3636 cm x 47.1333 cm
29.5 kg
Pricing Type
Build To Plan (BTP)
Limited warranty - 3 years - on-site
Server
Product Form Factor
Tower - 5U
Built-in Devices
Status LCD
Server Scalability
2-way
Hot-Swap Bays Qty
8
Processor / Chipset
CPU
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
Cache Memory
Installed Size
11 MB
Cache Per Processor
11 MB
RAM
Installed Size
8 GB
DDR4 SDRAM
Effective Memory Speed
2133 MHz
Rated Memory Speed
2667 MHz
DIMM 288-pin
Slots
16 (Total) / 15 (empty)
Registered, single rank
Configuration Features
1 x 8 GB
Hard Drive
SSD - hot-swap
1 x 240 GB
Storage Controller
1 x RAID
Controller Interface Type
SAS 12Gb/s
Storage Controller Name
Dell PERC H330+
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Matrox G200eR2
Video Memory
16 MB
Video Interfaces
VGA
Interface (Bus) Type
LAN-on-motherboard (LOM)
Ethernet Ports
2 x Gigabit Ethernet
Remote Management Controller
Integrated Dell Remote Access Controller 9 Enterprise (iDRAC9)
Bays
8 (total) / 7 (free) x hot-swap 3.5"
Slots
2 PCIe 3.0 x4 - half-length, full-height , 1 PCIe 3.0 x16 - full-length, full-height , 2 PCIe 3.0 x8 - half-length, full-height
5 x USB 2.0 - Type A (1 front, 4 rear) , 2 x LAN (Gigabit Ethernet) , 1 x management (NIC) , 1 x VGA (1 rear) , 1 x serial , 3 x USB 3.0 - Type A (1 front, 2 rear)
Bezel
Pricing Type
Build To Plan (BTP)
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Nominal Voltage
Power Provided
750 Watt
Operating System / Software
OS Provided
No operating system
21.8 cm
57.3636 cm
47.1333 cm
29.5 kg
10 °C
35 °C
10 - 80%
Case Style: Tower
Brand: Dell
Price Range Ex VAT: 1000 - 1500
